Inventor General
Active Contributor
sw_convert
Message 1 of 3 (544 Views)
Save As...... Previous Inventor format??
544 Views, 2 Replies
02-01-2013 11:10 AM
Greetings all,
Question:
Is it possible to save an Inventor model/dwg/assembly to a previous version of Inventor. (from 2013 to 2012, specifically)
I'm not sure if that is even an issue, but I don't have a version of Inventor earlier than 2013 to try it.  A customer is asking this question so they can view our Inventor files.  I spent quite a bit of time, looking for an option, but was unsuccesful.
Thanks in advance for any help you can offer on this.  :-)
*Pro
ampster
Message 2 of 3 (536 Views)
Re: Save As...... Previous Inventor format??
02-01-2013 11:33 AM in reply to: sw_convert
A search would have saved you the post!
The answer is the same for all solid modeling packages...
No.
Only option from 2013 is to save out as stp.
Couple of options for the 2012 (or previous versions) user is to open the stp or possibly download and install the feature recognition add-on from Autodesk Labs.
Active Contributor
sw_convert
Message 3 of 3 (520 Views)
02-01-2013 12:48 PM in reply to: ampster
Thank you!
Apologize for my laziness...... stressful, high pressure day, so posted and went back to work focus.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
