Inventor Forum
Same part different thickness
1 REPLY 1
F.Goncalves
252 Views, 1 Reply
Imagine that I have an part that is a simple square steel plate with Lenght*Width*Thickness.
Then in one assembly i want to add one plate with 200*200*10 and another with 200*200*5. Is it possible to have the same part with diferent dimensions? or do i really need to create an iPart. I'm having problems with my drawing manager software when i make iparts and i assemblys.....
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
F.Goncalves
1 REPLY 1
mpatchus
in reply to: F.Goncalves
I probably wouldn't create an iPart for just two variations of a simple plate.
I'd probably just open the plate, do a "Save As", then edit the thickness and save the part.
You could also do this in the assembly by using the "Save and Replace Component" function.
If you were going to require many different thicknesses, then I would consider making it an iPart.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
