Inventor General
Member
Message 1 of 9 (242 Views)
STRESS ANALYSIS ON A BOLT IN SINGLE SHEAR
242 Views, 8 Replies
05-09-2013 07:34 AM
Hello everyone.
My Stress analysis will run and process after i hit simulate but did not return result(Results tree is empty)
Anybody knows what's this please.
I'm running autodesk inventor pro 2013.
Thanks.
Member
Message 2 of 9 (235 Views)
Re: Stress analysis did not display result after simulation
05-09-2013 07:48 AM in reply to: cgelang
changing subject title.. thanks
*Expert Elite*
LT.Rusty
Message 3 of 9 (222 Views)
05-09-2013 09:19 AM in reply to: cgelang
Attach you files here, we'll take a look for you.
___________________________________________________________
Product Design Suite Ultimate 2013, 2014
Work: Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
Home: i7-4770k / ASUS Z87-Pro / 16GB / 250 GB SSD / 1 TB HDD / 3 TB USB3 HDD / 2xRadeonHD 4870 in CrossfireX
Laptop: Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
Member
Message 4 of 9 (201 Views)
05-09-2013 10:17 PM in reply to: LT.Rusty
Thank LT.
Please see attached part.
Very basic try.
 But after simulate, it says computing results but when done model tree is empty.
Thanks for your help.
Message 5 of 9 (192 Views)
Re: STRESS ANALYSIS ON A BOLT IN SINGLE SHEAR
05-10-2013 12:59 AM in reply to: cgelang
Do you have the visibility of Textures enabled?
See: http://beinginventive.typepad.com/being-inventive/2012/10/colors-missing-on-model-after-stress-analy...
Your sample runs fine on my laptop. See the screenshot in the attachment.
Roelof Feijen
_______________________________________________________________________________
Product Design Suite Ultimate 2014 | Simulation Mechanical 2014 | Simulation CFD 2014
Autodesk Inventor 2014 Certified Professional | Autodesk AutoCAD 2014 Certified Professional
Member
Message 6 of 9 (186 Views)
05-10-2013 01:34 AM in reply to: rfeijen
Thanks rfeijen,
I've checked and the texture is ON.
Please see attached, this is the result after running, though it computes and run simulate button.
Thanks for your time.
*Expert Elite*
LT.Rusty
Message 7 of 9 (167 Views)
05-10-2013 11:25 AM in reply to: cgelang
The image you attached in your last post ... I'm not sure what that is?
Anyway, your simulation.  I got it to run, but it took forever to mesh.  I'm not sure why it wouldn't run for you?
Anyway, about the mesh ... it's pretty dense, and probably far denser than you really need, especially around the outside.  Be aware that Inventor's FEA doesn't really like working with things that have a very high ratio of length and / or width to thickness.
Member
Message 8 of 9 (149 Views)
05-10-2013 07:04 PM in reply to: LT.Rusty
Thanks LT for running at your end, I think it has to do with my installation, I'll try to un-install and re-install inventor and see the result. Thanks also for the hints about the mesh dense, if you don't mind, what is the commen setting fo mesh to get fair result.
Thanks.
*Expert Elite*
LT.Rusty
Message 9 of 9 (125 Views)
05-11-2013 03:52 PM in reply to: cgelang
I start off leaving the mesh settings alone.  Just use the defaults, for a starting point.  After your first run (which will be a LOT quicker) you can adjust things locally, or use the convergence settings to refine things.  I generally do my first run with defaults, and then set the convergence to run again until it either hits 5% convergence or does 3-5 levels of refinement.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
