Inventor General
Active Member
mariappan.u
Message 1 of 7 (393 Views)
STP FILE SHEETMETAL FLAT PATTERN
393 Views, 6 Replies
12-06-2011 02:32 AM
Hi all,
I have stp file to convert sheetmetal flat pattern.i can convert some portion but i cant convert particular portions.
see attached file.
waitng for solution.
Message 2 of 7 (383 Views)
Re: STP FILE SHEETMETAL FLAT PATTERN
12-06-2011 04:43 AM in reply to: mariappan.u
You might be waiting a while - of course Inventor will not unfold a jpg image.
You will need to attach the ipt file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Active Member
mariappan.u
Message 3 of 7 (350 Views)
12-06-2011 08:00 PM in reply to: JDMather
I CANT ATTACH STP FILE IN THIS FORUM
Message 4 of 7 (341 Views)
12-07-2011 04:09 AM in reply to: mariappan.u
Right click on the file name and select Send to Compressed (zipped) Folder
and attach the resulting *.zip file here
or
attach the translated *.ipt file here.
Active Member
mariappan.u
Message 5 of 7 (321 Views)
12-08-2011 05:20 PM in reply to: mariappan.u
here is the attachment.
Message 6 of 7 (306 Views)
12-09-2011 05:05 AM in reply to: mariappan.u
If you look in this area from the right side this face (and I assume the opposite face) is warped.
This was hard to see from the jpg you originally posted.
You will have to Delete Face and rebuild that area of the part.
Message 7 of 7 (297 Views)
12-09-2011 06:56 AM in reply to: JDMather
Considering manufacturing tolerance - perhaps this is close enough.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
