HOW DO YOU CUT ACROSS THE BEND OF A SHEET METAL CYLINDER THAT WILL SHOW UP AS A STRAIGHT HOLE
ON THE LAY FLAT
Solved by JDMather. Go to Solution.
Solved by M.Peppel. Go to Solution.
Attach your file here if you can't figure it out.
What I need is to put a rectangular hole thru half on the attached cylinder
I extrude the geometry and thicken/offset than converted to sheet metal
the geometry came from a model that I need this part to match to I was trying to
avoid making the lay flat & folding
Hi Jerry,
you should have a look at the "Contour Flange" feature. This is the right tool to start with. It is always useful to just work with the options offered in the sheet metal environment this way you can ensure that the part will be able to unfold. Ones you build your base part, unfold it and create the desired cut fold it again and you will have the desired part.
I hope that this explanation helps
regards
Matthias
Works fine here.
