Inventor Forum
SAVE COPY AND REPLACE WITH I-LOGIC
9 REPLIES 9
Message 1 of 10
twinz3950
3372 Views, 9 Replies
I have searched the forums here but could not really find an answer.  I have an assembly that I am working on that will be used as a configurator, driven by I-logic. Everything is work fine but there is one part off the assembly that will be custom to each new assembly.  Is there a way to use I logic  to open the ipt file save it as copy with different name and replace the original in the assembly. I know this can be done manual through the productivity tab within the assembly environment, but I am trying to automate the process so the end user will just have to follow prompts that will be given by i-logic.
9 REPLIES 9
Message 2 of 10
twinz3950
in reply to: twinz3950
OK I have this code but I do not need it to go  through all the parts, is there any way to modify this so that it only looks for a part call "shell:1" with in the assembly?
Sub Main()
 Dim Path As String = ThisDoc.Path & "\"
 Dim FileChange As Boolean = False
 InvDoc = ThisDoc.Document
 Dim refDocs As DocumentsEnumerator = InvDoc.AllReferencedDocuments
 Dim refDoc As Document
 For Each refDoc in refDocs
 'MessageBox.show(refDoc.DisplayName)
 'input box to enter new file name
 NewFileName = InputBox("What is the new file name for " & refDoc.DisplayName & "?", "New File Name", refDoc.DisplayName)
 'NewFileName = InputBox("What is the new file name for " & refDoc.DisplayName & "?", "New File Name", iProperties.Value(refDoc.DisplayName, "Project", "Part Number"))
     'if the new file name is blank then use the same name
     If NewFileName = "" Then
         NewFileName = refDoc.DisplayName
     'if the user also types in the extesion then remove the extension.
     If NewFileName.EndsWith(".ipt") = True Then
         NewFileName = NewFileName.substring(0,NewFileName.length-4)
         'MessageBox.show(NewFileName)
     'if there is an change in the name then do the following.
     If refDoc.DisplayName <> NewFileName & ".ipt" Then
         'check to see the file already exist. if it does then replace.
         If System.IO.File.Exists(Path & NewFileName & ".ipt") Then
             Component.Replace(refDoc.DisplayName, Path & NewFileName & ".ipt", True)
         Else
             Dim oldName As String = refDoc.DisplayName
             'if it does not exist then recreate the file
             refDoc.saveas(Path & NewFileName & ".ipt",False)
             Call UpdateDrawing(Path, oldName, NewFileName)
         FileChange = True
 Next
 If FileChange = True Then
     NewAssemblyName = InputBox("What is the new file name for the assembly?", "New Assembly File Name", iProperties.Value("Project", "Part Number"))
     If NewAssemblyName <> "" Then
         Dim oldName As String = ThisDoc.FileName(True) 'include extension
         ThisDoc.Document.SaveAs(Path & NewAssemblyName & ".iam" , False)
         Call UpdateDrawing(Path, oldName, NewAssemblyName)
 iLogicVb.UpdateWhenDone = True
 End Sub
 Private Sub UpdateDrawing (ByVal Path As String, ByVal oldName As String, ByVal newName As String)
     Dim oDestinationDoc As DrawingDocument
     Dim strFileExtension As String = oldName.substring(oldName.Length-4,4)
     oldName = oldName.substring(0,oldName.Length-4)
     Dim sFileName As String = Path & oldName & ".idw"
     Try
         If System.IO.File.Exists(sFileName) Then
             oDestinationDoc = ThisApplication.Documents.Open(sFileName)
             oDestinationDoc.saveas(Path & newName & ".idw",False)
             Dim oDocDescriptor As DocumentDescriptor
             oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
             Dim oFileDescriptor As FileDescriptor
             oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
             oFileDescriptor.ReplaceReference(Path & newName & strFileExtension)
             oDestinationDoc.Update()
             oDestinationDoc.Close
     Catch
         MessageBox.Show("error")
     End Try
 End Sub
Message 3 of 10
pcrawley
I'm not in front of Inventor right now, so I can't check any of this, but using my (badly) calibrated eyeball, try the following.  (I note that the code references "display name" rather than filename - so if you rename anything in your browser, this is likey to fail!)
If refDoc.DisplayName = "shell:1" then
'This will find only "shell:1" and execute all the following code.
'If the refDoc.DisplayName is not "Shell:1" it'll jump to the red "End If" and proceed to check the next component.
     End If
     End If
     'if there is a change in the name then do the following.
         Else
         End If
         FileChange = True
     End If
 Next
'Not sure if you need any of the following as it appears to be building new sub-assemblies - and you are only replacing a part.
'If you don't need it, comment it out using a  '  at the beginning of each line.
' If FileChange = True Then
'     NewAssemblyName = InputBox("What is the new file name for the assembly?", "New Assembly File Name",iProperties.Value("Project", "Part Number"))
'     If NewAssemblyName <> "" Then
'         Dim oldName As String = ThisDoc.FileName(True) 'include extension
'         ThisDoc.Document.SaveAs(Path & NewAssemblyName & ".iam" , False)
'         Call UpdateDrawing(Path, oldName, NewAssemblyName)
'     End If
' End If
 End Sub 'I'm not sure about this line.
'It could exit the iLogic code at this point.  I've only ever used it to end a sub-routine, but none has been defined.
'Someone who understands code better than me will tell you what it does!
'And this next part is to do with Drawings?  Again, you can probably ditch this too.
Private Sub UpdateDrawing (ByVal Path As StringByVal oldName As StringByVal newName As String)
'     Dim oDestinationDoc As DrawingDocument
'     Dim strFileExtension As String = oldName.substring(oldName.Length-4,4)
'     oldName = oldName.substring(0,oldName.Length-4)
'     Dim sFileName As String = Path & oldName & ".idw"
'     Try
'         If System.IO.File.Exists(sFileName) Then
'             oDestinationDoc = ThisApplication.Documents.Open(sFileName)
'             oDestinationDoc.saveas(Path & newName & ".idw",False)
'             Dim oDocDescriptor As DocumentDescriptor
'             oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
'             Dim oFileDescriptor As FileDescriptor
'             oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
'             oFileDescriptor.ReplaceReference(Path & newName & strFileExtension)
'             oDestinationDoc.Update()
'             oDestinationDoc.Close
'         End If
'     Catch
'         MessageBox.Show("error")
'     End Try
End Sub
Peter
Message 4 of 10
twinz3950
thank you so much Smiley Happy
Message 5 of 10
pcrawley
Wow - you mean it worked?!!
Hope the rest of the project worked out too.
Glad I could help.
Peter
Message 6 of 10
Agenx
Hi
I have the same desire like twinz390 to rename a particular ipt file (L-B.ipt) in the collection (Ban- master- template.iam) and rename the iam to a new name.
I have tried to copy the ilogic code that are writting, but I can not get the piece of program to virke.I AM NO wizard on the iLogic programming
Does anyone have a suggestion?
Message 7 of 10
MTheDesigner
Here is a code I wrote to save and replace a part in an assembly. please note that it only works for parts not subassemblies as it is.
Dim oDoc As Document = ThisApplication.ActiveDocument
'Make sure we are in an assembly
If oDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject
	MsgBox("This code only works on assemblies", "Error")
	Return
'Pick the part and find the document path
Dim oPart As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Pick Your Item")
Dim oPartDoc As Document = oPart.Definition.Document
Dim oPartPathAndName As String = oPartDoc.FullDocumentName
Dim oPartPath As String = System.IO.Path.GetDirectoryName(oPartPathAndName)
'pick a new name
Dim NewPartName As String = InputBox("Please enter a new file name", "Name Part",System.IO.Path.GetFileName(oPartPathAndName))
'open the document
If NewPartName = "" Then
	Return
Try
	ThisApplication.Documents.Open(oPartPathAndName)
Catch
	MsgBox("Part path could not be resolved")
	Return
End Try
'Save a new version of the document
Try
	oPartDoc.SaveAs(oPartPath & "\" & NewPartName & ".ipt", True)
	oPartDoc.Close()
Catch
	MsgBox("Could not save the part")
	Return
End Try
Try
	oPart.Replace(oPartPath & "\" & NewPartName & ".ipt",False)
Catch
	MsgBox("Couldn't replace the part")
End Try
 Edit: Fixed a bug and added handling for if the cancel button is pressed.
Message 8 of 10
MTheDesigner
in reply to: MTheDesigner
Well guys, turns out we all missed the easy way out. Inventor has a built in tool called save and replace, its under the productivity tab in the assembly ribbon, does exactly what we were all trying to do with code.
Message 9 of 10
pcrawley
I might be missing something, but from the original post: "I know this can be done manual through the productivity tab within the assembly environment, but I am trying to automate the process so the end user will just have to follow prompts that will be given by i-logic."
Peter
Message 10 of 10
MTheDesigner
in reply to: pcrawley
Ah fair enough, you caught me sleeping. If they know the part though, my code will work as long as they just sight the known part in place of the pick command.
