Inventor General
New Member
Message 1 of 20 (9,726 Views)
Runtime error r6025 pure virtual function call
9726 Views, 19 Replies
04-21-2010 06:44 AM
Hi all
Has anybody had this issue with Inventor 2011 runtime error R6025 pure virtual function call
This happens when deleting a view from a drawing sheet.
This is a C++ run time error, could this be an issue with Inventors programme code which needs
a hotfix??????????????
Kind regards
Adam. Edited by: abutcher on Apr 21, 2010 1:44 PM
**Master
Message 2 of 20 (9,724 Views)
Re: Runtime error r6025 pure virtual function call
04-21-2010 06:53 AM in reply to: abutcher
does this happen with all drawing files?
does this happen on just your workstation or canit be repeated on others?
do you get an error report? ( I recall having this issue with Inv 2008 or 2009 once, and the error repost told AD what the issue was, I think it was later fixed in a SP)
if it's specific to one drawing:
Is this an assembly or part?
does the model have any constraint errors, sketch errors, etc. (use Rebuild All to make certain)
how many sheets are there in the drawing?
does this happen with every view on the drawing?
Valued Contributor
Message 3 of 20 (9,696 Views)
07-06-2010 03:35 PM in reply to: abutcher
Hey there, we have been getting this error coming up on one of our workstations running Inventor 2011 in Windows XP.
The error seems to usually occur when the user is moving apart around or zooming etc in the assembly environment. The workstation has a Quadro 3500 card with the latest certified driver from the Autodesk hardware website. I can't figure out why we are getting the errors. Anyone else been having these issues?
Message 4 of 20 (9,619 Views)
08-03-2010 11:21 AM in reply to: karlbeardsley
Any luck with finding a fix for this?  We have one machine that this happens too.  Seems to be happening when the user moves a section view created one one sheet to another.  Was just dragging the view in the browser.  Then when trying to switch activating sheets it popps up.  Any thoughts?
Windows XP, 64-bit.  (inventor and vault 2010 still installed)
Thanks.
If this response answers your question please click "Accept as Solution".
Employee
Message 5 of 20 (9,613 Views)
08-03-2010 02:28 PM in reply to: abutcher
Hi! Could you post an example here  or send it to me? It looks like it is an unhandled exception. If the files are greater than 9MB, I can set up a secure account for you to upload.
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Autodesk, Inc.
Message 6 of 20 (9,588 Views)
08-04-2010 05:58 AM in reply to: johnsonshiue
Yes it is larger and will need the account to download.  I noticed you said secure, so if we could just send it directly to you that would be great.  I would prefer not to post it on the internet.  Did you need the assembly and part files and everything as well or just the DWG file (inventor dwg)?
my email is kmiller@coldspringgranite.com
Thanks.
Message 7 of 20 (9,586 Views)
In the meantime I did request to our IT staff to have them try doing a repair install.
Distinguished Contributor
aguitton116
Message 8 of 20 (9,230 Views)
11-03-2010 06:32 AM in reply to: abutcher
Hi, does anyone have a clue about that.
One of my customer has the same error on a HP workstation with Inventor 2011 SP1, windows 7 pro x64, and Vault Collaboration 2011 update 2.
This happens when he switches to hidden lines mod in a sketch (part environment).
Valued Mentor
Message 9 of 20 (8,695 Views)
02-11-2011 07:52 AM in reply to: abutcher
I just had a user get this error when editing a part file in the context of an assembly.  He's running Inventor Pro 2011 SP1 on a Windows 7 x64 machine.  Any idea what's up with this?
John Weiss
CAD Administrator
Follett Corporation
John C Weiss Jr.
CAD Administrator
Follett Corporation
New Member
Spielvogel
Message 10 of 20 (8,477 Views)
03-01-2011 12:21 AM in reply to: jweiss
Dear Mr. Weiss,
     did you find a solution for this problem (Runtime error r6025)? A colleague of us has the same problem. He's running Inventor 2011 on a Windows XP x64 machine.
with best regards
Klaus Spielvogel
MBE Coal & Minerals Technology GmbH
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
