Inventor Forum
Runtime error P6025 pure virtual function call on Program
1 REPLY 1
msz.kowalik
2275 Views, 1 Reply
Welcome!
I have problem with Autodesk Infrastructure Design 2013.
Error i get is:
"Runtime error P6025 pure virtual function call on Program"
I'm trying to make an animation using anipath command. I've used every combination of settings - low/medium/high. Every time autocad/inventor crashes on about 130 frame.
As I said i used Autodesk Infrastructure Design Suite Standard 2013 and AutoCAD 2012 and both programs crashes with the same error at the same time.
I also googled for tips about this error and i found this. Visual C++ i now up-to date and it has all libraries. I have no idea why it still doesn't work.
1 REPLY 1
blair
in reply to: msz.kowalik
This type of error could be caused if runtime components of Visual C++ libraries are missing or because of third-party software.
Follow the methods listed below:
Method 1:
If the issue is caused due to missing Visual C++ libraries, you may download and install the Runtime components of Visual C++ libraries from the link below:
This error may occur when the Microsoft .NET Framework installation on the computer is damaged or is missing.
Try the below step to reinstall and repair the Microsoft .NET Framework installation on the computer and later check if you can install the software.
a) Click the Start button, click  Control Panel, click Programs, and then click "Turn Windows features on or off." If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
b) Locate Microsoft .NET framework 3.5.1, uncheck the box, click OK and restart the computer.
c) After the restart again open "Turn Windows features on or off" and place  a check mark next to Microsoft .NET framework 3.5.1 and restart the computer.
Step 2
If the above step fails then I would suggest that you manually download and install Microsoft Visual C++ 2005 and 2008 Redistributable Package and check if you can install the software.
In Programs and Features, do you show that you have installed Microsoft Visual C++ 2005 Redistributable and Microsoft Visual C++ 2008 Redistributable? If not, download from the links here.
Visual C++ 2005 Redistributable Package for (X86)
 http://www.microsoft.com/downloads/en/details.aspx?FamilyId=32BC1BEE-A3F9-4C13-9C99-220B62A191EE&dis...
Visual C++ 2005 Redistributable Packager for (x64)
 http://www.microsoft.com/downloads/en/details.aspx?FamilyID=eb4ebe2d-33c0-4a47-9dd4-b9a6d7bd44da&dis...
Microsoft Visual C++ 2008 Redistributable Package (x86)
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9B2DA534-3E03-4391-8A4D-074B9F2BC1BF&dis...
Visual C++ 2008 SP1 Redistributable Package for (x64)
 http://www.microsoft.com/downloads/en/details.aspx?familyid=BA9257CA-337F-4B40-8C14-157CFDFFEE4E&dis...
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
