Inventor General
Valued Contributor
CJ.10E-10mm
Message 1 of 6 (175 Views)
Rule to Control the Visibility of Work Features in Inventor Pro 2014
175 Views, 5 Replies
10-02-2013 12:10 PM
Is there a way to write a set of rules so that I can switch Work Features On and Off via a Text Parameter.
I have an assembly made up of a number of parts used hundreds of times within in various sub-assemblies. If I make a particular sub-assembly 'Invisible' then subsequently 'Visible,' all work features that had previously been set to be 'Invisible' are switched to 'Visible' also.
Likewise if I simple want to set a particular Work Features' Visibility in one particular sub-assembly, I would like to be able to do this via a Text Parameter rather than having to laboriously scroll down the Assembly switching the visibility of features on and off.
At the moment if I turn the visibility of say a Work Plane On in a sub-assembly then all sub-assemblies deploying the same part switch the visibility of that Work Plane on too. Hence I cannot see my work for Work Planes.
Obviously the Global Switch under View is of no avail,
So I would like to be able to create a Text Parameter for each sub assembly and in turn each Work Feature with a Yes/No Visibility switch controlled via a set of Rules in iLogic.
Can anyone kindly help please?
Thank you so much.
CJ
Distinguished Mentor
pcrawley
Message 2 of 6 (151 Views)
Re: Rule to Control the Visibility of Work Features in Inventor Pro 2014
10-03-2013 05:15 PM in reply to: CJ.10E-10mm
Try this: http://inventortrenches.blogspot.co.nz/2013/03/turn-onoff-all-workfeatures-with-ilogic.html
Should be easier than finding a parameter to toggle - or just adapt the code to suit.
Peter
Valued Contributor
CJ.10E-10mm
Message 3 of 6 (142 Views)
10-03-2013 05:41 PM in reply to: pcrawley
Hi Pcrawley,
Thanks for that but of course it is a blanket on/off and I need to be selective.
pcrawley
Message 4 of 6 (139 Views)
10-03-2013 05:43 PM in reply to: CJ.10E-10mm
Indeed it is.  Hence the "adapt to suit" comment.  I just offered it as a starting point rather than a complete solution.
Peter
Valued Contributor
CJ.10E-10mm
Message 5 of 6 (135 Views)
10-03-2013 05:48 PM in reply to: pcrawley
Hi Pcrawley,
Yes but sadly I don’t have the skills to modify so extensively.
Thank you for your kind suggestion anyway.
Valued Mentor
stephengibson76
Message 6 of 6 (45 Views)
04-17-2014 02:11 AM in reply to: pcrawley
I know this is an old post but...  The code works great for part work features, how do I make it include assembly and sub assembly work features?
Stephen Gibson
View stephen gibson's profile on LinkedIn
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
