Inventor General
Member
Message 1 of 17 (560 Views)
Accepted Solution
Rubber Track Design
560 Views, 16 Replies
01-09-2013 07:17 PM
Trying to model a track but i have it in more of a triangular orientation then an ovel like this sample picture. Any advice on how to pattern the tread and inner lug around any shape i desire? I have tried making an extrusion on one of the flat faces and then patterning it around but it keeps the lug in the same orientation and does not follow the contour nicely. Any advice for me
Valued Contributor
Message 2 of 17 (548 Views)
Re: Rubber Track Design
01-09-2013 11:36 PM in reply to: mklassen78
You can do rectangular pattern in part enviroment along choosen curve, and set orientation to direction1. This should work.
I hope that's what you're looking for.
Greg
Factory design suite 2013 premium
Some old workstation ...
Fancy HP LCD
:smileyhappy:
*Expert Elite*
Message 3 of 17 (530 Views)
01-10-2013 04:42 AM in reply to: mklassen78
mklassen78 wrote:
Trying to model a track but i have it in more of a triangular orientation . Any advice for me?
See this document pg 16
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 4 of 17 (478 Views)
01-10-2013 06:19 PM in reply to: JDMather
Thank you for your replies! JDMather that does work to pattern around and i can get it to follow the contour i want but it leaves a gap between the "treads" as it is patterned around a curve. It does not keep tangent. Any solution to that?
*Expert Elite*
Message 5 of 17 (475 Views)
01-10-2013 06:55 PM in reply to: mklassen78
Attach your ipt file here.
Member
Message 6 of 17 (465 Views)
01-10-2013 08:21 PM in reply to: mklassen78
Hope this helps more
*Expert Elite*
Message 7 of 17 (450 Views)
01-11-2013 04:47 AM in reply to: mklassen78
I don't see a pattern in the file you attached?
When I attach my solution the sketch for the tread will be on the XY plane.
The extrusion for the belt will initially be a surface body and then Thicken after the Pattern of the treads.
Member
Message 8 of 17 (435 Views)
01-11-2013 08:07 AM in reply to: mklassen78
That is why im on this forum, It will not allow me to pattern and keep tangency, It just gives an error. The lugs i want to pattern are in the file though.
*Expert Elite*
Message 9 of 17 (431 Views)
01-11-2013 08:33 AM in reply to: mklassen78
mklassen78 wrote:
.... It just gives an error.
Post screen shot of error.
*Expert Elite*
Message 10 of 17 (424 Views)
01-11-2013 09:07 AM in reply to: JDMather
I experimented with this one a bit more.
It is going to be a bit more work than I originally thought.
Because the tread cleats bend around the curves - my attempt would be with patterned-trimmed surfaces, thicken and trim again.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
