Inventor General
Distinguished Contributor
Message 1 of 3 (231 Views)
Round fuction
231 Views, 2 Replies
11-14-2012 04:40 PM
I am using Inventor 2012.  I am trying to use the Round fuction in a parameter with no luck.
I have a the following parameters
wire_offset                in    wire_space+wire_wdt     0.231186
wire_offset_round     ul    round(wire_offset/1 in)    1.000
When I do wire_offset_round like this it works.  But if I want it to a 3 place decimal it does not work
wire_offset_round     ul    round((wire_offset/1 in), 3 ul)
According to the Inventor help, I should be able to do this.  But I can't.  I even tried it without the ul after the 3 and nothing.  Any clues?
Valued Mentor
rhasell
Message 2 of 3 (215 Views)
Re: Round fuction
11-14-2012 10:19 PM in reply to: cadcamm99
Hi
I am not sure which help you read, but, NO it will not work.
round (expr) will round to the closest whole number.
The syntax you have used WILL work with iLogic, and will change the rounding of an exported parameter, found in "iProperties, Custom"
What you can do for your current issue is change the precision of the value.
STEPS:
- Parameters
- RMB on "wire_offset"
- select "Custom property format"
- Change "precision" to 3
This will change the display of the value but not the value its self.
I will try and find the syntax to change the value, I have used it, but it does not always go in the direction you want it to. (Floor and ceil)
Reg
Autodesk Product Design Suite Premium 2014 SP1-Update 2 Build 222
Intel Core i7 (950@3.07GHz)/Win7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti
Please accept as a solution if it fixes your problem.
*Pro
sbixler
Message 3 of 3 (193 Views)
Re: Round fuction
11-15-2012 04:52 AM in reply to: cadcamm99
In your example, I'm not clear how .231186 rounds to 1.000?  Doesn't work that way for me in 2013, anyway.  If, as I suspect, you want the number rounded to three decimal places, then the following should work:
wire_offset_round   ul   round(wire_offset * 1000 ul / 1 in) / 1000   .231000
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
