Inventor Forum
Rotation-Translation Constraint on Threaded Features
1 REPLY 1
TheRoundMoundofRebound
1314 Views, 1 Reply
Good Day, Just want to learn on how to make this Clamp Rod to Clamp Base Spacer Turn relationship.
this is from the Clamp Project on this site: Inventor Wizard,  The Clamp Lever is turning or rotating the clamp rod into the Clamp Base Spacer  but I could not simulate the Thread or the Screw motion if that is the term, or the 1 or 1/2 turn of the Clamp Rod to 1 Pitch movement,  plus I can't seem to put the Rod inside the Clamp Base Spacer hole when the Contact Solver is ON, maybe modeling issue on my part.
Attached is my assembly, appreciate any help.
1 REPLY 1
Bump.
Just moving this back to the top.
I intended to get to it earlier, but busy for now.
Maybe someone else can show the solution (you do not need or want Contact Sets).
The CADWhisperer YouTube Channel
