Inventor General
Distinguished Contributor
Closterman
Message 1 of 5 (619 Views)
Rotate text in a sketch
619 Views, 4 Replies
08-02-2007 08:59 AM
hy I can't rotate my text in the sketch ?? If I right click on the text (duting the a sketch edit) the "rotate 90" and "text box" option are gray.
If I edit my text, I'n not able to click on the rotation box, normaly for that !! It's a bug or I make something wrong. !!
MattH
Message 2 of 5 (619 Views)
Re: Rotate text in a sketch
08-02-2007 09:17 AM in reply to: Closterman
You could try my iNudge addin available from
http://www.mcadforums.com/forums/viewtopic.php?t=4778
Regards
MattH
mcgyvr
Message 3 of 5 (619 Views)
08-02-2007 09:21 AM in reply to: Closterman
when in edit sketch mode right click on the text and uncheck the "text box"..then right click again and your rotate options should be available then.
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Closterman
Message 4 of 5 (619 Views)
08-02-2007 09:32 AM in reply to: Closterman
AAHH !!! Your right !! Thank a lot !
JDMather
Message 5 of 5 (619 Views)
08-02-2007 09:58 AM in reply to: Closterman
Dimension the text box angle to any angle.
Tip 40 & 41
http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
