I can only get horizontal or vertical 'orientation' in "Break" view.
How do I rotate it to say 60degrees to use on an iso view?
I don't think you can put a break on an isometric view.
If you put the break on the base view and then project that view to the iso then the break is added. See picture.
Edit : you can place a break on an isometric view but the output is dodgy.
As posted you can't, but you can suppress the broken base view so all you would see is the single ISO broken view.
