With johnsonshiue and wh help i made my roof.
It will work, i made something like this before, different software and long time ago
So THANK YOU, and i just have one question.
In this roof: one spline, one template x8, simmetrical roof
If i want to make the roof with of centre top hole, everyting else stays the same, non symmetrical.
Do i have to make 8 different splines to make 8 different templates or there is a smart and nice way?
Solved by Cadmanto. Go to Solution.
Can you post your part to take a look at?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I am looking at your model. The first question I have is, in your assembly model you have 8 sides, yet in your picture it shows 6 sides. Which one do you really want? That matters because it will affect the width of each panel.
Regardless, this is what I came up with. See the attached models.
You might also want to figure out how to pattern the panels in the part instead of creating an assembly.
I am confused about the design intent.
Something like this?
HI , Thank You for the answer, and i am sorry for not precise question.
Amount of sides and shape of top hole doesn't matter (bdw i need to find time to lern i find out how Cadmanto made it )
All that samples are symmetric roofs, but what if the top hole is not in center of roof and width an hight of roof stay the same
All I did was take your part file, shrink the smaller hex sketch to be smaller. Meaning a greater (larger dimension spacing size from large hex) distance from the large hex.
That made the top portion of the surface come to more of a point in the top middle.
Then in the assembly I just created an assembly cut for the hole.
Hope this makes sense.
