Inventor Forum
Roller Ghain - Double pitch
6 REPLIES 6
ScottSwens
403 Views, 6 Replies
I am using the Roller Cain generator to design a chain drive. I wish to use ASME B29.3 Double-Pitch Power Transmission Roller Chain #2050. The generator says the pitch is 1.125.
If I look up the same chain from US Tsubaki, they are giving me a pitch of 1.250.
Whos is correct?
I am using Inventor 2013.
thanks
6 REPLIES 6
mrattray
in reply to: ScottSwens
I use #2050 chain daily. Pitch is 1.250".
In fact, here is my purchase specs out of my ERP system for 2052 chain in case it helps you:
PP-CH-2052-D3-05
BLM CHAIN #2052-D3 @ 5" CENTERS
>Carrier Roller Chain
>Double pitch roller chain with oversize rollers
>D3 attachments on 5" centers
> 1.250" pitch
> Roller dia .750 /19.05mm
> Roller width .375 / 9.525mm
> Pin dia .200 / 5.08mm
> Plate height .594" / 15.0876mm
> Plate thickness 0.079"
> Maxium Allowable loads 970 LBS
> Average Ultimate strength 6,620 LBS
> Tensile strength 6100 LBS
Mike (not Matt) Rattray
blair
I would go with the data from the chain supplier that you will be using.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mrattray
In fact, I'm curious where they get 1.125 from, because 2040 is 1.0"...
ScottSwens
in reply to: mrattray
that makes two of us.
jletcher
That is why I don't use it or content center parts.
 Burn me one time never again cost me lots...
dan_inv09
in reply to: jletcher
Ditto
