Inventor General
baga7362
Message 1 of 4 (375 Views)
Right hand and left hand parts
375 Views, 3 Replies
06-21-2013 10:56 AM
I have a modeled right hand part and a detail drawing of that right hand part with a pin that defines r.h from l.h. and I would like to save them as a left hand part then change the model by reversing the pin. How would I proceed with this task?
Valued Contributor
danielw88
Message 2 of 4 (369 Views)
Re: Right hand and left hand parts
06-21-2013 11:04 AM in reply to: baga7362
Whenever i do parts that have a right and a left and are the same, only mirrored, i use the following process.
I model the entire part as either a right or a left.
Once complete, i use the mirror function to mirror the entire part and i select 'delete original part'
In my i-parts table, i will create a member file for the right hand and left hand parts.
I will, then, suppress the mirror for the original part and include the mirror on the opposite part.
From there, if there are some features that are different from left to right, those features can be added and then suppressed/excluded from the i-part table.
*Pro
jletcher
Message 3 of 4 (365 Views)
06-21-2013 11:10 AM in reply to: baga7362
Or you can do a derived part and use the mirror option at the bottom...
Look up derived parts in help.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
*Expert Elite*
dan_inv09
Message 4 of 4 (353 Views)
06-21-2013 11:33 AM in reply to: baga7362
You should probably use Design Assistant, or Copy Design (or whatever the Vault function is called) but for something seemingly this simple I'd make a copy of the drawing and a copy of the part/assembly then rename the original - put an x in front of it or something - and when you open the drawing it can't find the right hand, so tell it to use the copy. Then change the copy to be the left hand and fix the right hand's file name (and clean up the drawing) and you're done.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
