Inventor Forum
Revistion Table Does Not Increment Correctly
3 REPLIES 3
m.granata
322 Views, 3 Replies
I am Using Inventor 2013.  Every time I add another revision row to a revision table the revision level does not increment by one digit.  The automated results I get usually follow this sequence:  1-3-6-12-24... and if I edit, for example, revision level entry 3 to revision level entry 2 as it should be I then get this sequence:  1-2-4-8-16...
This revision level issue has occurred only in Inventor 2013 before and after the current service pack was installed.  Anybody have any thoughts as to why this occurs?
Mike
3 REPLIES 3
in reply to: m.granata
Does this happen on all drawings, or just a particular one?
I added a revision line on a drawing today with no problem.
Can you post files so I can see if it happens here?
m.granata
Yes it happens on all idw drawings.  Although, I haven't tried starting with a different idw template.  Maybe, it is something related to the template I am starting with?  Sorry, I don't feel comfortable enough uploading a client's drawing to the discussion group.
Mike
AndyWallace
I have seen odd behavior also, usually with Inventor bumping the next rev +2 instead of +1. I think I have seen it work correctly on some drawings but most of the time the rev will be incorrect and I have to manually edit it.
Andy Wallace
Autodesk Inventor (2016) (3 years)
previously Solidworks (6 years)
