Inventor General
Valued Contributor
Jefkee
Message 1 of 9 (424 Views)
Accepted Solution
Revision tag
424 Views, 8 Replies
10-02-2012 02:39 AM
I'm looking at a way to reduce the size of the revision tag in inventor, cause its size doesnt fit in our drawings, we have the habit to put as much info **** possible on the sheets but when we get a revision the tag is too big..
 Is this possible?
Currently using Inventor2012 & soon will be using 2013
Greetings.
Inventor 2013
*Pro
jletcher
Message 2 of 9 (413 Views)
Re: Revision tag
10-02-2012 04:12 AM in reply to: Jefkee
Not to sure if to many users use the revision tag that comes with Inventor don't really work like it should. I made my own tag and block to fill in.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Contributor
Jefkee
Message 3 of 9 (411 Views)
Re: Revision tag
10-02-2012 04:14 AM in reply to: jletcher
& why does it not work like it should?
Inventor 2013
*Pro
jletcher
Message 4 of 9 (406 Views)
Re: Revision tag
10-02-2012 04:24 AM in reply to: Jefkee
Well if I remember when you tag lets say one revision with a 1 or A depending on what you do and then you make another revision and it is a 2 or B the 1st tags you put will also change to a 2 or B and it should not they should stay the revision they were. And in the description part the text wrap don't work right so it can cut off words li
ke this.
So with all the time it takes to make it right was not worth it.
James Letcher
Valued Contributor
Jefkee
Message 5 of 9 (401 Views)
Re: Revision tag
10-02-2012 04:48 AM in reply to: jletcher
when i upgrade my revision it keeps previous tags as they should so thats no problem. :smileyhappy:
Inventor 2013
*Pro
jletcher
Message 6 of 9 (399 Views)
Re: Revision tag
10-02-2012 04:50 AM in reply to: Jefkee
Oh they fixed it and only took 6 releases.
James Letcher
*Pro
sbixler
Message 7 of 9 (395 Views)
Re: Revision tag
10-02-2012 05:03 AM in reply to: Jefkee
If I recall correctly, the size of the tag is directly proportional to the text size.  It leaves too much white space, in my not-so-humble opinion, so the tags look huge, but they work fine otherwise.  To reduce the size, edit your library/template style and set the text smaller.
Valued Contributor
Jefkee
Message 8 of 9 (382 Views)
Re: Revision tag
10-02-2012 07:20 AM in reply to: sbixler
And its not possible to reduce the white space? between the triangle & letter/number?
Inventor 2013
*Pro
jletcher
Message 9 of 9 (380 Views)
Re: Revision tag
10-02-2012 07:22 AM in reply to: Jefkee
Nope again why I don't use them.
James Letcher
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
