Inventor General
Cadmanto
Message 1 of 3 (357 Views)
Reversing Weld Assembly??
357 Views, 2 Replies
04-06-2012 07:16 AM
I have an assembly that I thought in the beginning of its creation I thought I would be able to add welds to it.
I wasn't successful which is not the issue, but rather since I have NO welds on this, and this assembly shows as a weld model, is there a way to reverse this?  I need to add an assembly cut to this model and it is not allowing me due to this.
Scott
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Curtis_Waguespack
Message 2 of 3 (348 Views)
Re: Reversing Weld Assembly??
04-06-2012 07:40 AM in reply to: Cadmanto
Hi Cadmanto,
For some reason Autodesk has not provided a way to revert back to an regular assembly once it has been converted to a weldment. There are 2 workarounds that I've used in the past:
1) Leave it as weldment assembly and just use the Preperations or the Machining tools to add the assembly features, and just don't add weld information.
2) Place the weldment in a new assembly, and promote all of the components up to the top level and then delete the weldment assembly. Then simply save the new assembly as the correct part number.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Cadmanto
Message 3 of 3 (343 Views)
04-06-2012 07:50 AM in reply to: Curtis_Waguespack
Thanks Curtis,
I think Autodesk should seriously take a look at this and make a way to reverse this.
I went for option #1.  That worked fine.  Thanks for jogging my memory.  I forgot about that little tool.  :smileyhappy:
Option #2 I would think would give me grief when it comes to vault and the duplicate file name thing.
I know it would be a new file, but my expierence to this point would tell me that vault would detect a difference
and throw this message back to me not allowing the checking in of the file.
Thanks again
Scott
Best Regards,
Scott McFadden
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
