Inventor Forum
Reversing Weld Assembly??
2 REPLIES 2
Cadmanto
1991 Views, 2 Replies
I have an assembly that I thought in the beginning of its creation I thought I would be able to add welds to it.
I wasn't successful which is not the issue, but rather since I have NO welds on this, and this assembly shows as a weld model, is there a way to reverse this?  I need to add an assembly cut to this model and it is not allowing me due to this.
Scott
Best Regards,
Scott McFadden
(Colossians 3:23-25)
2 REPLIES 2
Hi Cadmanto,
For some reason Autodesk has not provided a way to revert back to an regular assembly once it has been converted to a weldment. There are 2 workarounds that I've used in the past:
1) Leave it as weldment assembly and just use the Preperations or the Machining tools to add the assembly features, and just don't add weld information.
2) Place the weldment in a new assembly, and promote all of the components up to the top level and then delete the weldment assembly. Then simply save the new assembly as the correct part number.
I hope this helps.
Curtis
Thanks Curtis,
I think Autodesk should seriously take a look at this and make a way to reverse this.
I went for option #1.  That worked fine.  Thanks for jogging my memory.  I forgot about that little tool.  Smiley Happy
Option #2 I would think would give me grief when it comes to vault and the duplicate file name thing.
I know it would be a new file, but my expierence to this point would tell me that vault would detect a difference
and throw this message back to me not allowing the checking in of the file.
Thanks again
Scott
Best Regards,
Scott McFadden
