Inventor Forum
Retrieve Missing Section Pattern?
4 REPLIES 4
Cadmanto
286 Views, 4 Replies
I have a section view in which the section lines are MIA.
Is there a way to retrieve them?  So I can change the scale?
Best Regards,
Scott McFadden
(Colossians 3:23-25)
4 REPLIES 4
mpatchus
in reply to: Cadmanto
Try editing the view (either by double clicking on the view, or right clicking the view and selecting edit).
Go to the Display Options tab and ensure that the HATCHING box is checked.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
cwhetten
This might be a long shot, but did you use the content center to create that channel?  If so, it might not be sectioning the channel because it is a "standard" part.  Depending on your document settings and / or drawing view standards, standard parts may not automatically participate in section views.
If this is the case, no hatching would show up.  Try editing the drawing view > Display Options tab > Section Standard Parts > change to "Always".  If what I described above is true, then you will suddenly have hatching in your view.
Cadmanto
in reply to: mpatchus
Thanks for the reply, but the hatching is checked.
Best Regards,
Scott McFadden
Cadmanto
in reply to: cwhetten
Ding, ding, ding!!!
After you posted this I felt like I just had a duh moment.  I realiezed that I have experienced this before, but forgot at the moment that these were CC parts.  You were right.  As soon as I selected "Always my hatching appeared.
Best Regards,
Scott McFadden
