Inventor General
Kevin_Raymond
Message 1 of 8 (252 Views)
Retrieve Assembly Feature Dimensions?
252 Views, 7 Replies
08-13-2012 11:59 AM
I have tried to research this problem to no avail.
I am trying to retrieve dimensions from an assembly. The features that I want were created in the assembly itself, not on the original parts in the assembly. I can manually dimension some of the features, but there are others that I need to retrieve. When I retrieve dimensions from the assembly, I am only given the original dimensions for the parts.
Thanks in advance.
Employee
johnsonshiue
Message 2 of 8 (249 Views)
Re: Retrieve Assembly Feature Dimensions?
08-13-2012 12:14 PM in reply to: Kevin_Raymond
Hi! I must not have followed the workflow correctly. Somehow I am not seeing the behavior you are describing here. I am able to retrieve dimensions associated with assembly features.
In the Retreive Dimensions dialog, did you choose "Select Features" option in "Select Source"? Or it is set to "Select Parts" by default?
Thanks!
Principal SQA Engineer, Inventor
Mechanical Design
Kevin_Raymond
Message 3 of 8 (245 Views)
08-13-2012 12:39 PM in reply to: johnsonshiue
I may not have explained my problem well.
I have an assembly of two parts. As an example, if I were to create a 2D sketch in the assembly and then make a revolved cut, I cannot retrieve those dimensions. The only dimensions that I  can retrieve are the dimensions of the parts as they were when I first placed them in the assembly. I have tried the "Select Features" option, but it is not giving me different results.
Employee
johnsonshiue
Message 4 of 8 (241 Views)
08-13-2012 12:52 PM in reply to: Kevin_Raymond
Hi! Do you mind posting the simple dataset you are having trouble retreiving dimensions from? I can take a quick look and see where the exact problem is.
Thanks!
Mechanical Design
Kevin_Raymond
Message 5 of 8 (234 Views)
08-13-2012 01:35 PM in reply to: johnsonshiue
I have attached some sample files.
In the example, I assembled parts A and B to create Assembly C. In the assembly, I went to the "Model" tab and created a 2D sketch. I then revolved that sketch to make a revolved cut. I placed the assembly into Drawing D, which shows the modified assembly. However, retrieving dimensions does not allow me to retrieve the dimensions from that revolved cut.
I can't seem to add more than three files, so I will attach the drawing in my next post.
Kevin_Raymond
Message 6 of 8 (233 Views)
08-13-2012 01:36 PM in reply to: Kevin_Raymond
Attached is the drawing.
Employee
johnsonshiue
Message 7 of 8 (228 Views)
08-13-2012 02:20 PM in reply to: Kevin_Raymond
Hi! Thank you for providing the files! Indeed, Retrieve Dimensions on assembly features does not seem to work in the same way as on part features. I am forwarding this issue to development for review.
Thanks!
Mechanical Design
Distinguished Contributor
petestrycharske
Message 8 of 8 (165 Views)
12-18-2012 08:16 AM in reply to: johnsonshiue
We were able to retrieve some assembly feature dimensions (haven't tried it on anything other than a pattern of hole features), by changing the parameter settings.  In the assembly model open the Parameters dialog box and place a check mark in the "Export" check box for every dimension that you might want to retrieve.  Couldn't get it to work for constraint offset dimensions, but let us know if this process works for your assembly features.  Have a most blessed day!
Peace,
Pete
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
