Inventor General
Distinguished Contributor
Message 1 of 6 (147 Views)
Retracting fillets
147 Views, 5 Replies
12-06-2006 10:43 AM
When I am adding blends or fillets to a 3D model, sometimes after picking a few edges I will inadvertently select a wrong edge. Can I deselect the edge and resume selecting edges for the fillets or do I have to start over from the beginning?
Message 2 of 6 (147 Views)
Re: Retracting fillets
12-06-2006 11:14 AM in reply to: carbonated
Hold down the Shift or Ctrl key and select the edge again to de-select.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Member
Message 3 of 6 (147 Views)
12-07-2006 02:57 AM in reply to: carbonated
after completing the module you can change the radius or edges by select or unselect the edges for fillet go to edit future do the changes in dialogue box
Message 4 of 6 (104 Views)
03-22-2012 06:54 AM in reply to: carbonated
Is there another way to retract fillets?  I've tried the ctrl, shift, and both at once.  None of those key selections did nothing with my 3D drawing.  Is there something I could do in my settings to adjust this?
Message 5 of 6 (100 Views)
03-22-2012 07:24 AM in reply to: lindgrenn03
Attach your file here.
There is another (trivially simple) method - but I am reluctant to mention it without first seeing your ipt file.
Message 6 of 6 (87 Views)
03-22-2012 09:08 AM in reply to: lindgrenn03
Do you have multiple sets of fillets within one feature?
You have to select the correct set of fillets to remove from.
The set of fillets you are working with will highlight a slightly different color.
In the attached I can add to or deselect the ones with a L_BoreRad radius but I would not be able to deselect the one with the M_Rad radius.
(If you are using the goofy junk to the top of that picture you are on your own it only gets in my way, I'll hold off on ranting about Autodesk changing for change's sake later.)
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
