Inventor General
Active Contributor
JazzJPH
Message 1 of 14 (777 Views)
Accepted Solution
Retaining Developed Length on Flexible Cable Tray - Adaptivity?
777 Views, 13 Replies
03-15-2012 03:58 AM
Hi everyone,
I worded the title so it can be found easily for anyone with the same problem.
Also - I'd like to mention first that I have searched and searched, finding many threads & reading through them, but despite trying all the suggestions I could not make this thing work.  I am using Inventor 2010 - so half the threads 2011 onwards couldn't apply due to newer model versions (I was just going to download a fixed one and modify it to suit my problem).
Anyway - I want to put a cable tray going from a sliding door to a fixed piece of steelwork.  When the door opens and closes, I want the cable tray to adjust to suit the sliding door.  I'll upload the file that I have made if someone can figure out what I have done wrong.  When i drag the sketch it all moves accordingly, but when I placed in the assembly and make it adaptive it does nothing, it will not constrain and it will only bring up the errors.
I know I am missing something which should be very clear to me.  If someone could get that cable moving with those two plates I can incorporate it into my sliding doors.  I would appreciate it a lot!
Thanks in advance
Inventor 2012
Windows 7 64-Bit SP1
Intel(R) Xeon(R) CPU X5570 @ 2.93GHz
NVIDIA Quadro FX 3800 (Avail. Graphics Memory 4067MB - Ded. 1024 MB)
12 GB RAM
Distinguished Mentor
pauldoubet
Message 2 of 14 (771 Views)
Re: Retaining Developed Length on Flexible Cable Tray - Adaptivity?
03-15-2012 04:08 AM in reply to: JazzJPH
I didn't look at the attached files. It sounds like you need to take a look at making the part or sub assembly 'Flexible'. An example of this would be a hinge that you want to use in a higher level assembly and have the door swing, you set the hinge assembly to 'Flexible' in the higher level assembly to allow the hinge parts to move in the higher level assembly.
Hope this helps, Paul
Active Contributor
JazzJPH
Message 3 of 14 (769 Views)
03-15-2012 04:21 AM in reply to: pauldoubet
As far as I know, it isn't possible to make a part flexible is it?  I don't think there'll be any point in trying that due to the fact that I cannot get the part to move about, so putting it another level into an assembly would do nothing, as the part itself will not move.
The only way I can get the part to move is by going into the sketch and mouse-dragging one bit of it, and it all moves together (retaining the developed length), nicely.
I want to be able to put this part straight into the assembly, fix one end to the sliding door, the other to the steelwork holding the door, and then have it change to suit the door as it opens/closes.
Inventor 2012
12 GB RAM
*Expert Elite*
harco
Message 4 of 14 (757 Views)
03-15-2012 05:46 AM in reply to: JazzJPH
Try taking the constraint off the curve centre point to origin and constrain the endpoint of the short leg to the origin.
*Expert Elite*
JDMather
Message 5 of 14 (752 Views)
03-15-2012 06:02 AM in reply to: JazzJPH
 The meaning of making a sub-assembly "Flexible" in Inventor (or SWx) is different than what you might be thinking.
You are probably thinking flexible like a rubber band.  In these programs setting a sub-assembly to Flexible means allowing the sub to have motion on it's unconstrained degrees of freedom and for multiple instances of the same sub to move independently.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Contributor
JazzJPH
Message 6 of 14 (737 Views)
03-15-2012 07:47 AM in reply to: JDMather
I understand the flexible sub-assemblies, but I was referring to the .ipt not being able to be made flexible.  For example if I was to drop that long part into an assembly, I could not right click on it in the browser and tick the "Flexible" option as it will not be there due to it being a part (.ipt).
I tried moving the centre point constraint so the top of the short end was constrained to it.  This worked and the small assembly I attached in my first post operates OK.  However, when I place the long piece in a larger assembly with steelwork in place of the upper piece of plate, and a sliding door in place of the lower piece - Inventor will have none of it.  I have tried the same constraints and all I keep getting is the red cross with constraint errors.  I can't understand why the same principle in a larger assembly will not work.
Inventor 2012
12 GB RAM
Valued Mentor
RayFeiler
Message 7 of 14 (730 Views)
03-15-2012 08:52 AM in reply to: JazzJPH
This will work if you rebuild your model with the extrusions normal to the direction of adaptability. With this method you can change Mate1 in my example but you cannot drive it. Sorry I can only upload IV2012 data.
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
Valued Mentor
RayFeiler
Message 8 of 14 (728 Views)
03-15-2012 08:53 AM in reply to: RayFeiler
The assembly.
*Expert Elite*
JDMather
Message 9 of 14 (716 Views)
03-15-2012 09:09 AM in reply to: JazzJPH
You attached an assembly.
Active Contributor
JazzJPH
Message 10 of 14 (712 Views)
03-15-2012 09:14 AM in reply to: JDMather
I think we are getting confused here.  I attached the assembly with two plates.  The actual application I will be using it in is a sliding door mechanism.  I did this because the size of the assembly is massive, and wouldn't be able to be attached.  The upper plate is to represent the steelwork, the lower plate is to represent the sliding door.  The information I gain from this thread would be used to implement the runner in the sliding door assembly.  I would just be placing the long part (.ipt) into the assembly with the steelwork and the door.
Inventor 2012
12 GB RAM
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
