Inventor Forum
Resolve Link, link unused/unfound
10 REPLIES 10
Message 1 of 11
703 Views, 10 Replies
I have a somewhat complicated .ipt part and I keep getting a Resolve Link error pointing to a part called standoff.ipt. I had used this part before, but no longer am using it. I can't see it being referenced anywhere. It is not in the Parameters box or anywhere I can see. Is there a way to figure out where in my part the reference to "standoff.ipt" is coming up?
Thanks!
10 REPLIES 10
Message 2 of 11
cwhetten
Try going to Tools > Manage Links.
-cwhetten
Please click "Accept as Solution" if this response answers your question.
Message 3 of 11
Unfortunately the "Manage Links" button is grayed out for me.
Message 4 of 11
cwhetten
What version of Inventor?  I could help you faster if you posted the part.
Message 5 of 11
in reply to: cwhetten
I'm using Inventor 2012. Sorry I don't think I can post the part as it is proprietary. Is there anywhere else in the model where a link to another part might be?
Message 6 of 11
blair
Is the part located in a directory outside of your path(s) defined in your current active Project file?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 7 of 11
in reply to: blair
No it's in the path. The file actually no longer exists and can't be recovered. But I don't need it anyway.
Message 8 of 11
cwhetten
Maybe it was adaptive at some point with projected sketch entities?
Or maybe you derived the existing part from the other one, and there is a derived part node?
Other than these and the ones you mentioned, I'm not sure where else they could be linked.
-cwhetten
Message 9 of 11
Now I'm even more confused. So I created a copy of the part and deleted every sketch and feature from the part, as well as every parameter. And I'm still getting the unresolved link.
Message 10 of 11
cwhetten
Can you post the part with all of the features deleted?
Message 11 of 11
Ok so I fixed it. I found an old version of the part and put it in the directory. Only then could I see that the parameters section was still referencing this part. So I deleted the corresponding parameters. Then I was able to delete the referenced part, and the error went away. There has to be a way to do this if I wasn't able to find this part though, right? I find it funny that I couldn't see the error in the parameters window until I actually found the part.
