Inventor General
patrjck
Message 1 of 13 (293 Views)
Request: printer configurations!
293 Views, 12 Replies
07-20-2011 06:35 AM
Dear Autodesk, I routinely use A, B, C, and D size drawings.  C and D size go to our wide format printer and then I have to select the paper size.  It would be really nice if Inventor could automatically print D size drawings on D size paper and so on.  I'm envisioning some kind of configuration manager that I set up once and for all, then never worry about setting up printers again.  You would set a print configuration for every size of drawing.  Please consider this feature in future releases.
*Expert Elite*
sam_m
Message 2 of 13 (284 Views)
Re: Request: printer configurations!
07-20-2011 06:56 AM in reply to: patrjck
print profiles have been requested many times over the years...  (without them it makes printing from the Task Scheduler a joke as you can only print documents of the same paper-size together, and how do you know the paper-size without opening each idw, so defeating the purpose of a batch-print tool...)
all I can suggest is to use KWIKPrints for now:
http://www.kwikmcad.com/icode/KWiKPrints32_64/KWiKPrints32_64.aspx
Please mark this response as "Accept as Solution" if it answers your question...
but please understand that the solution may not be the answer you're wanting to hear...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love :smileyvery-happy:
Lithium - helping nntp users with mania, depression and headaches
Message 3 of 13 (282 Views)
07-20-2011 06:59 AM in reply to: patrjck
You can always try an addin, a great one is called Swift Prints. Here is a link to the download.
http://cadtoolbox.com/swift-prints/
jdits7
Autodesk Inventor Certified Professional
Blog - http://inventortopix.blogspot.com
Twitter - @InventorTopixJD
patrjck
Message 4 of 13 (275 Views)
07-20-2011 07:27 AM in reply to: jdits7
Swift prints is pretty nice, saves a lot of clicks.  Now if only it auto detected the sheet size ... thanks for the tip!
*Expert Elite*
karthur1
Message 5 of 13 (251 Views)
07-20-2011 10:08 AM in reply to: jdits7
I've bn using swift prints for about a year.  I can only use it to print to my pdfcreator.  Works great for this... two clicks and it is printed.
If I try to print to a network printer it doesnt work.  Wondering if others have the same issue with swiftprints.
patrjck
Message 6 of 13 (244 Views)
07-20-2011 10:33 AM in reply to: karthur1
Both printers I use are networked and work just fine.  Windows 7 32 bit, Inventor 12
Distinguished Contributor
Message 7 of 13 (238 Views)
07-20-2011 10:48 AM in reply to: patrjck
Just curious: why 32-bit Windows 7?
KState92
Inventor Professional 2014 64 SP1 Update 3
Windows 7 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
patrjck
Message 8 of 13 (228 Views)
07-20-2011 11:23 AM in reply to: kstate92
Our IS department doesn't support 64 bit.  This turned out for the best because we use an ancient wide printer that Xerox doesn't write 64 bit drivers for.  I have 2 computers and run 64 bit on my main workstation and print from my 32 bit laptop.  Now you know!
Thomas.Rambach
Message 9 of 13 (223 Views)
07-20-2011 11:37 AM in reply to: karthur1
Have you downloaded the latest version of Swift Prints? It's new as of 06/25/2011.
*Expert Elite*
karthur1
Message 10 of 13 (198 Views)
07-20-2011 12:19 PM in reply to: Thomas.Rambach
Thomas,
Yes, I am using V2.0 (b2).  When I print via swiftprints, it sends the file to the printer. At the printer, there is a message on the screen that says "Paper Size and Type Mismatch".  If I am printing 8 1/2 x 11, I can select it from the printer screen and it prints just fine.  Our printer has 8 1/2 x 11, 11 x 17 and Ledger size loaded in it.
When I configured swiftprints, I just selected the paper size that was on the drop-down list.
Kirk
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
