in case of replacing a component in an assembly the present item number in (structured) BOM table is reassigned through a new one. This cause a lot of troubles in our firm, because this requires rework of item numbers after each replace action. I expected that especially in case of an replace of all occurrences, the item number is kept. Is there a setting to keep item numbers after a component was replaced?
Thanks for any answer in advance!
Solved by csaba.stupak. Go to Solution.
