Repeatable error
Issue Description:
Accidental deletion of iMate folder inside a IPT files.
Error Method:
Congratulations! You have now deleted "Extrusion2" and the "iMates" folder at the top of tree.
DANGEROUS SIDE EFFECT
I have not looked into this same issue inside assemblies.
Inventor Hotfix?
TomPy
Hi Tom_WH,
Thanks for the clear steps and example file with which to test this.
I don't have an explanation as to why using delete all features below EOP would delete the iMates folder and all of the iMates contained within, but I was able to reproduce it using Inventor 2010 and 2012. It appears you're currently using 2011, so I didn't test that version, but I assume the issue is present in that version as well.
I think someone from Autodesk will have to have a look and tell us why this is happening, but it doesn't seem like this would be an as designed behavior. So I'll go out on a limb here and say that you've found a bug.
Thanks for sharing this with the rest of us. I think this could be a particularly problematic bug for an organization that uses iMates a lot.
As a work around, I would suggest to just delete features by selecting them (one at a time or using CTRL select) and deleting them, rather than using delete all features below EOP.
I hope this helps.
Curtis
Just to be clear on this, I tested for the dependencies to ensure that the issue was not just that iMates created based on a feature are being removed when that feature is removed. The original test file posted by Tom_WH demonstrates this, but just to be sure you can see the iMates folder and all of the iMates getting deleted regardless of dependencies by following these quick steps:
The iMates folder is removed, even though the sketch and feature are not related to the geometry being deleted.
I hope this helps.
Curtis
