Inventor Forum
Repeatable Crash/System Freeze - Routed Systems 2010
1 REPLY 1
-Aaron-
203 Views, 1 Reply
I found this out while I was creating a new iPart, and never really noticed it because I try to use unique names for my parameters. When this first happened I accidently set the parameter name to "S", cancelled the error message and my system froze.
I've tried this on multiple templates (Default & User Created; IPT & IAM) and the crash/freeze is repeatable.
1.  Start new part
2.  Open Parameters Dialog and Add a new parameter
3.  Use a parameter name that you know will be incorrect, i.e.- S, KG.  Something that Inventor already uses as a parameter name.
4.  You should get an error message saying something along the lines of "parameter name in use blah blah"
5.  Cancel error message.
6.  System freezes.  I can't ESC out of the dialog, can't cancel and it turns my screen to the faded white....
Can anyone please confirm that I am not the only one with this issue???
Thanks in advance,
-Aaron-
Formerly ASI_Aaron
i7-6700k
ASUS Z170-AR
Gigabyte GTX 970
16gb RAM
512gb Samsung 950 Pro
1 REPLY 1
