Inventor Forum
Reorient Triad
6 REPLIES 6
850 Views, 6 Replies
Reorient Triad
In a part file, how do I rotate the part around the x axis by 90 degrees so that the triad's y axis becomes alligned with what is now the z axis on the triad?
6 REPLIES 6
JDMather
Right mouse button Redefine first sketch might be a solution.
Attach your file here.
Curtis_Waguespack
Hi fsfguy,
In addition to JDMather's suggestion to redefine the first sketch, you can also use the Move Bodies tool to do this:
There's more on this technique at this link:
http://inventortrenches.blogspot.com/2011/06/change-origin-of-imported-model.html
I hope this helps.
Curtis
Thanks!  I really appreciate the solutions!
@Curtis - I read the link you listed, if I want to move to a specific point on the part rather than the center of gravity, is there a way to get the coordinates for a specific point?  Btw, I really appreciate your book, it lives next to my computer.
JDMather
Can you attach your file here.
in reply to: JDMather
File attached.
Curtis_Waguespack
Hi fsfguy,
Thanks for supporting the book, I'm happy to hear that you find it useful.
Selecting a vertex with the Distance measure tool (Tools tab > Distance button)  should give you its location. In this image a 10mm cube is centered on the origin point, so measuring one of the corners gives the results shown. You coud also create a temporary sketch or workpoint to find the location of some point that does not have a selectable vertex.
I hope this helps.
Curtis
