I am using Inventor Studio to render an image of my scene. However, when I use the "Illustration" mode (instead of "Shading"), the transparency disapears! Is there a way to have transparency when rendering images in "Illustration" mode?
Thank you for your help!
Solved by emaiolino. Go to Solution.
Dear, good day.
There is no way (that I know of) to make a render illustration mode, leaving a piece or part of the "Transparent" assembly. This mode represents an image "Drawn and painted" with colors, manner in which it is not possible to do this.
It is the base part as in this example:
