Inventor General
Member
andrew.cox
Message 1 of 6 (353 Views)
Renaming sheets in a multi-sheet IDW....
353 Views, 5 Replies
10-04-2012 12:04 PM
Is there any easy way to have sheet name automatically pull the "description" iProperty from the part that is on the sheet?  It can be very handy in a multi-sheet drawing for each sheet to have a descripive name in the browser, but the only way to do this (that I know of) is to manually change it.
Andrew
*Expert Elite*
Curtis_Waguespack
Message 2 of 6 (342 Views)
Re: Renaming sheets in a multi-sheet IDW....
10-04-2012 01:21 PM in reply to: andrew.cox
Hi andrew.cox,
Here's an iLogic rule to do this. Note that description might not write to the sheet name correctly if it has characters such as commas in it.
I hope this helps.
Curtis
Dim oSheets As Sheets
oSheets = ThisDoc.Document.sheets
Dim oSheet As Sheet
For Each oSheet In oSheets
	oSheet.activate
	Dim oDrawingView As DrawingView
	oDrawingView = oSheet.DrawingViews(1)
	oModelName = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument.DisplayName
	oDesc = iProperties.Value(oModelName, "Project", "Description")
	oSheet.Name =  oDesc
Next
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Member
andrew.cox
Message 3 of 6 (318 Views)
10-05-2012 05:55 AM in reply to: Curtis_Waguespack
Hi Curtis,
Thanks for this info!  However, I have not even used iLogic, so I don't know what to do with this.  Any chance you could point me towards a good tutorial, or provide me instructions yourself?
Cheers,
Andrew
*Expert Elite*
Curtis_Waguespack
Message 4 of 6 (301 Views)
10-05-2012 08:38 AM in reply to: andrew.cox
Hi andrew.cox,
This should cover it:
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
Member
andrew.cox
Message 5 of 6 (286 Views)
10-05-2012 12:30 PM in reply to: Curtis_Waguespack
Hi Curtis,
I'm having some trouble with the code you supplied.  When I enter in into the "rule", I get this error....
I cut-and-paste the code exactly as you had it in your previous post.  Any thoughts?
Andrew
*Expert Elite*
Curtis_Waguespack
Message 6 of 6 (250 Views)
10-08-2012 07:12 AM in reply to: andrew.cox
Hi andrew.cox,
Most likely there is an issue with a line wrap due to this forums formatting, or something like that. Attached is the rule in a text file, you can copy and paste from it.
If you see the same results post back.
I hope this helps.
Curtis
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
