Inventor General
*Friedman, Aaron R.
Message 1 of 13 (93 Views)
Renaming parts that occur in multple assemblies
93 Views, 12 Replies
12-04-2002 02:24 AM
What is the correct procedure for renaming a part that occurs in more
than one assembly? If I bring the part up in DA, I can a "Find Files" to
see where the part is used, but RMB on "action" won't let me "rename"
Aaron R. Friedman
ARF Designs
Distinguished Contributor
Message 2 of 13 (93 Views)
Re: Renaming parts that occur in multple assemblies
12-04-2002 03:25 AM in reply to: *Friedman, Aaron R.
are all the assemblies subs of a main assembly if so just open the main assembly to rename when you do the one it will do the rest in the main assembly
*Friedman, Aaron R.
Message 3 of 13 (93 Views)
Re:
12-04-2002 04:40 AM in reply to: *Friedman, Aaron R.
No, not all of the assemblies are subs of a main. So, I guess I have to
DA each top level assembly? But once I rename it in one, it's going to
screw up the others.
Aaron
> assembly
Message 4 of 13 (93 Views)
Re:
12-04-2002 04:45 AM in reply to: *Friedman, Aaron R.
are they all differnt projects just maped to the libary?
or all in same project?
*Berry, Patrick
Message 5 of 13 (93 Views)
12-04-2002 05:17 AM in reply to: *Friedman, Aaron R.
I thought this was impossible to do as well till someone in this group
showed me the light. The first thing is to select ANY one of the assemblies
containing the part. Expand the list and highlight the part itself. Rename
the part and leave it highlighted. Next, use the lower search to look for
any linked .idw, .iam, and .ipn files connected to the part. In the Action
column under each associated file select UPDATE. This will change the name
of the part in all the other assemblies, drawings and presentations it's
used in.
To me, it seems that the way this should be done is to open design assistant
on the part first, change the name, and then have it automatically update
the name change to all associated files. I wonder if Adesk has a reason why
it's not done this way.
Pat
"Aaron R. Friedman" wrote in message
news:3DEE4865.3060807@xprt.net...
> Aaron R. Friedman
> ARF Designs
*Friedman, Aaron R.
Message 6 of 13 (93 Views)
Re:
12-04-2002 06:31 AM in reply to: *Friedman, Aaron R.
They are all in the same project.
Aaron
*Friedman, Aaron R.
Message 7 of 13 (93 Views)
Re:
12-04-2002 06:38 AM in reply to: *Friedman, Aaron R.
Thanks Pat.
I imagine I don't do a save after the first part is renamed, but wait
until all associated files have the part renamed? Or does it matter?
Aaron
> used in.
> Pat
>>Aaron R. Friedman
>>ARF Designs
*Berry, Patrick
Message 8 of 13 (93 Views)
Re:
12-04-2002 07:27 AM in reply to: *Friedman, Aaron R.
I don't know. I've never tried saveing before updating.
Anyone?
Pat
news:3DEE83EF.10109@xprt.net...
> Thanks Pat.
> Aaron
assemblies
Rename
for
Action
name
> > used in.
assistant
update
why
> > Pat
> >>Aaron R. Friedman
> >>ARF Designs
*mpower
Message 9 of 13 (93 Views)
Re:
12-04-2002 09:36 PM in reply to: *Friedman, Aaron R.
I've been watching this subject because I would really like to know how to
do this as well. Here's my problem so far. I can pull up an assembly in
DA. I click the Manage icon and I see my parts in the tree. I highlight
the part I want to change, but I can't figure out how to rename it or do
anything with it. RMB does nothing. What am I missing?
Mike
"Patrick Berry" wrote in message
news:48D81F56A3AD091B36C45E763D352921@in.WebX.maYIadrTaRb...
assemblies
Rename
Action
name
> used in.
assistant
why
> Pat
> > Aaron R. Friedman
> > ARF Designs
*KJohnson
Message 10 of 13 (93 Views)
Re:
12-04-2002 09:50 PM in reply to: *Friedman, Aaron R.
RMB in the action column. Then RMB on the file name.
Kathy Johnson
"mpower" wrote in message
news:B7634222C71C69E918CA6C4431F5FE19@in.WebX.maYIadrTaRb...
> Mike
> assemblies
> Rename
for
> Action
> name
> > used in.
> assistant
update
> why
> > Pat
to
> > > Aaron R. Friedman
> > > ARF Designs
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
