Inventor Forum
Renaming parts that occur in multple assemblies
12 REPLIES 12
Message 1 of 13
233 Views, 12 Replies
What is the correct procedure for renaming a part that occurs in more
than one assembly? If I bring the part up in DA, I can a "Find Files" to
see where the part is used, but RMB on "action" won't let me "rename"
Aaron R. Friedman
ARF Designs
12 REPLIES 12
Message 2 of 13
jiml
are all the assemblies subs of a main assembly if so just open the main assembly to rename when you do the one it will do the rest in the main assembly
Message 3 of 13
No, not all of the assemblies are subs of a main. So, I guess I have to
DA each top level assembly? But once I rename it in one, it's going to
screw up the others.
Aaron
> assembly
Message 4 of 13
jiml
are they all differnt projects just maped to the libary?
or all in same project?
Message 5 of 13
I thought this was impossible to do as well till someone in this group
showed me the light. The first thing is to select ANY one of the assemblies
containing the part. Expand the list and highlight the part itself. Rename
the part and leave it highlighted. Next, use the lower search to look for
any linked .idw, .iam, and .ipn files connected to the part. In the Action
column under each associated file select UPDATE. This will change the name
of the part in all the other assemblies, drawings and presentations it's
used in.
To me, it seems that the way this should be done is to open design assistant
on the part first, change the name, and then have it automatically update
the name change to all associated files. I wonder if Adesk has a reason why
it's not done this way.
Pat
"Aaron R. Friedman" wrote in message
news:3DEE4865.3060807@xprt.net...
> Aaron R. Friedman
> ARF Designs
Message 6 of 13
They are all in the same project.
Aaron
Message 7 of 13
Thanks Pat.
I imagine I don't do a save after the first part is renamed, but wait
until all associated files have the part renamed? Or does it matter?
Aaron
> used in.
> Pat
>>Aaron R. Friedman
>>ARF Designs
Message 8 of 13
I don't know. I've never tried saveing before updating.
Anyone?
Pat
news:3DEE83EF.10109@xprt.net...
> Thanks Pat.
> Aaron
assemblies
Rename
for
Action
name
> > used in.
assistant
update
why
> > Pat
> >>Aaron R. Friedman
> >>ARF Designs
Message 9 of 13
I've been watching this subject because I would really like to know how to
do this as well. Here's my problem so far. I can pull up an assembly in
DA. I click the Manage icon and I see my parts in the tree. I highlight
the part I want to change, but I can't figure out how to rename it or do
anything with it. RMB does nothing. What am I missing?
Mike
"Patrick Berry" wrote in message
news:48D81F56A3AD091B36C45E763D352921@in.WebX.maYIadrTaRb...
assemblies
Rename
Action
name
> used in.
assistant
why
> Pat
> > Aaron R. Friedman
> > ARF Designs
Message 10 of 13
RMB in the action column. Then RMB on the file name.
Kathy Johnson
"mpower" wrote in message
news:B7634222C71C69E918CA6C4431F5FE19@in.WebX.maYIadrTaRb...
> Mike
> assemblies
> Rename
for
> Action
> name
> > used in.
> assistant
update
> why
> > Pat
to
> > > Aaron R. Friedman
> > > ARF Designs
Message 11 of 13
In order to "Rename" or "Replace" a part, the status can not be "Released".
If the part or assembly has a "Released" status, then the Replace and Rename
options will be grayed-out.
> Mike
> assemblies
> Rename
for
> Action
> name
> > used in.
> assistant
update
> why
> > Pat
to
> > > Aaron R. Friedman
> > > ARF Designs
Message 12 of 13
Nope. Tried that. RMB does nothing. Parts are WorkInProgress too. Does
the part need to be checked-out, or possibly all assemblies containing the
file have to be checked-out? Does it just not work with semi-isolated mode?
"KJohnson" wrote in message
news:235EDA4391F40D219C45E4ACDF61179E@in.WebX.maYIadrTaRb...
> Kathy Johnson
to
in
highlight
> > Mike
> > assemblies
> > Rename
> for
> > Action
> > name
it's
> > > used in.
> > assistant
> update
reason
> > why
> > > Pat
more
Files"
> to
"rename"
> > > > Aaron R. Friedman
> > > > ARF Designs
Message 13 of 13
Never mind the check-out status, it makes no difference.
news:DD5248E6A1D28AEB3675B3F4EB949F25@in.WebX.maYIadrTaRb...
mode?
> > Kathy Johnson
how
> to
> in
> highlight
do
> > > Mike
group
> > > assemblies
> > > Rename
look
> > for
> > > Action
the
> > > name
> it's
> > > > used in.
> > > assistant
> > update
> reason
> > > why
> > > > Pat
> more
> Files"
> > to
> "rename"
> > > > > Aaron R. Friedman
> > > > > ARF Designs
