Inventor General
Member
wiptheman
Message 1 of 6 (810 Views)
Remove Yellow Sketch line when inserting an image - Autodesk Inventor
810 Views, 5 Replies
02-12-2012 10:40 AM
Hi All,
I have a basic problem but I can't seem to be able to get around it. I added an image to a sketch successfully but it cam with a yellow line around it (see attached) and I can't remove it. In the sketch properties I was able to change it's color to black to make less visible but it's still there.
Any clue as to how I can make it disappear ?
Thanks for your help.
Kev
JDMather
Message 2 of 6 (802 Views)
Re: Remove Yellow Sketch line when inserting an image - Autodesk Inventor
02-12-2012 12:06 PM in reply to: wiptheman
Use Decal command to attach the image to your model.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
wiptheman
Message 3 of 6 (794 Views)
02-12-2012 12:34 PM in reply to: JDMather
Thanks a lot JD this indeed solved the problem !
In case someone looks for the function it's here: Ribbon: Model tab Create panel Decal
p.chubbock
Message 4 of 6 (632 Views)
08-17-2012 03:12 AM in reply to: wiptheman
Thanks for the extra info wiptheman!
Member
smcgregory
Message 5 of 6 (66 Views)
06-10-2014 02:29 PM in reply to: p.chubbock
How do you remove the yellow sketchboxes. I drew a rectangle and extruded backwards and now there is a yellow sketchbox around the face that I used to extrude on. How do I remove this?
JDMather
Message 6 of 6 (59 Views)
06-10-2014 03:34 PM in reply to: smcgregory
Turn off the visibility of your sketch.
Attach your *.ipt file here if you can't figure it out.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
