Hi bhahn,
You can right-click on one of the ordinate dimensions and deselect Hide Origin Indicator from the list.
I hope this helps.
Curtis
You can delete the view and make a new view and re-dimension without using a plain ordinate.
Chain Ordinates don't bring that piece of clumsy code along.
After tripping over these after "Replace Model", I just dumped the view and started from scratch. I re-appears from being "Hidden".
So much for automation. This is cluncky.
I don't think there was any actual problem identified in the previous conversation that needed to be fixed. What is it that you hoped would happen in the intervening nine years?
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
Allow users to delete the Datum mark. This is a nuisance during the Replace Model Reference command.
It reappears when the dimensions become dissociated from a part they reference.
I then has to be hidden again.
How exciting. One of my early posts from way back when I was just learning Inventor has sprung back up. I see that I never properly thanked everyone for their help in a problem I no longer really remember. I guess I've gotten used to Inventor's idiosyncrasies at this point!
