Inventor General
New Member
pohudon
Message 1 of 7 (1,461 Views)
Recording a Drive Constraint animation in assembly
1461 Views, 6 Replies
06-17-2011 08:02 AM
When I record an animation in .avi using the Drive Constraint command here's what pops :
The codec you selected to compress this AVI video stream cannot handle the current screen color depth and/or the graphics frame size. Please try another codec.
Then I press OK and it records but the AVI file is empty and no video is watchable.
What can I do?
I'm using Autodesk Inventor 2012 ans a windows 7 64bit brand new computer with Nvidia graphic card.
Active Member
JONOELLRICH
Message 2 of 7 (1,414 Views)
Re: Recording a Drive Constraint animation in assembly
08-30-2011 09:02 PM in reply to: pohudon
Similar issue here, with the occasional twist that often the 'record' button does not stay depressed.  After loading the TSCC codec from Techsmith I can now get it to act like it's recording (same behavior in Drive Constraint and animations in .ipn files) while the animation runs, but afterwards I get a 0 Byte file and of course I can't watch it, either.
Have you had any luck finding a fix?  I'm also on a fairly new machine with Win7/64.  I have made movies on this machine before, but now I just get these empty avi and wmv files.
Jon
Active Contributor
khosking
Message 3 of 7 (1,206 Views)
02-05-2012 07:22 PM in reply to: JONOELLRICH
Hey Team,
Prior to using the "Drive Constraint" option to record a .WMV or .AVI animation, be sure that your AntiVirus is disabled. I've seen a few cases recently where the movie file either fails to generate or is created and saved with 0KBs after attempting to save the "Drive Constraint" animation. Upon disabling AV, the animation file is then created and saved as expected.
Cheers,
Karl
Active Member
JONOELLRICH
Message 4 of 7 (1,203 Views)
02-05-2012 07:48 PM in reply to: pohudon
In my case the issue traced to Service Pack 1, and the hotfix that followed it fixed the issue for me.
Jon
New Member
zachars
Message 5 of 7 (1,031 Views)
05-13-2012 11:06 PM in reply to: pohudon
Go to your Application Options and navigate to the Hardware tab.  Set your graphics to compatability mode and restart Inventor.
Valued Mentor
Rich.O.3d
Message 6 of 7 (1,026 Views)
05-13-2012 11:56 PM in reply to: khosking
khosking wrote:
Hey Team,
..., be sure that your AntiVirus is disabled....
Cheers,
Karl
i wish it was that easy
You should see the reaction when someone says to the IT dept ..."ok i just need to disable the anti-virus for a little while"
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
*Expert Elite*
Curtis_Waguespack
Message 7 of 7 (1,015 Views)
05-14-2012 07:11 AM in reply to: pohudon
Hi everyone,
Here is the link to the hotfix for this issue:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17804829&linkID=9242019
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
