Inventor Forum
Recess Action Gear Design
1 REPLY 1
BCrosby
1717 Views, 1 Reply
I am currently working in IV2012 and have a need to design Recess Action Gears. We have been doing this for years with a DOS based program but this is getting harder to use as technology advances. Can this be done in Inventor? Any recommendations are appreciated.
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
1 REPLY 1
JDMather
in reply to: BCrosby
From Manual of Gear Design: Helical and Spiral Gears, Volume III
Recess Action Gear
RECESS ACTION GEARS, ALSO KNOWN AS LONG AND SHORT ADDENDUM GEARING, INCREASES THE ADDENDUM ON THE DRIVER AND REDUCES IT ON THE FOLLOWER TO OBTAIN AS MUCH RECESS ACTION AS POSSIBLE. THIS INCREASES THE EFFICIENCY AND WEAR LIFE OF THE GEARS. SEE SECTION TWO, P. 52.
What problem do you anticpate having with Inventor in doing these designs?
