In my quest to find out how much machine specs can improve rebuild speeds I thought I would make a challenging part and see if anyone would be interested in comparing rebuild times.
Under the sweep edit sketch5 and change the dimension of 30 to 40. See how long it takes to rebuild after you press finish sketch.
My machine takes 24 seconds in both 2011 & 2012.
Specs are
Windows XP64
Duo Core E8400 3.0 GHz
8Gb ram
Quadro FX 570 card.
Thanks.
@MikahBarnett3563 wrote:25 seconds on my laptop.
This is a great thread because it now gives me DATA that says it's time for a new workstation.
Before you spend on a new system look into over clocking. I went from 24 sec's at 3GHz to 19 sec's overclocked to 3.4Ghz. Just search for how to do it with the motherboard you have. I would also wait to see if 2013 has any more multi core support. If not then get the fastest you can afford without worrying about number of cores.
The results seem to be suggesting that RAM and video card are less important than processor speed and you can get an I3 or I5 at 3.4Ghz and an I7 4 core at 3.6Ghz much cheaper than the 6 core ones.
I now have a cpu monitor running and notice that it max's out when rotating which explains why changing cards made no difference, the cpu seems to be doing some of the calculations, so maybe card ram doesnt matter as much as we think.
IVP 2011 SP2 = 15.8 seconds
IVP 2012 SP1 = 17.2 seconds
Dell Precision M4600
Windows 7 Pro 64-bit
i7-2620M 2.7Ghz Dual core
8GB Ram DDR3 1333Mhz
Nvidia Quadro 1000M 2GB GDDR3
128 GB SSD
@Blair wrote:It comes down to the clock speed of a single core in the CPU when dealing with IPT and IAM files. If you could get a really fast single core CPU for IPT and IAM files, it would be all you need.
IDW creation with IV2012 does take advantage of multi cores, FEA and Studio also take advantage of multi CPU cores.
Unfortunately, from what I've seen, FEA in Inventor professional does not not use more than 1 core.
Just chipping in with my result, pretty similar to most:
18.4 sec from finish sketch
Specs:
Inventor professional 2012 SP1
Win7 - 64
CPU I7 860 @ 2.80 GHz
8GB RAM
Nvidia Geforce GTS 250 - driver version 280.26
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Seems 17 seconds is about right, it is the same time as Blair who has almost identical hardware. When running a single process my CPU only ramps up from 3.33Ghz to 3.6Ghz however the newer i5 & i7 xxxxK chips ramp up to well over 4 Ghz when running a single process. This is why some people are seeing quicker times on newer hardware.
Regards
Martin
15.3 seconds with Inventor 2011
HP Z210
Xeon E31240 @ 3.30 GHz
12 GB
Win7 64 bit
Quadro 2000
13.8 sec
Xi® MTower™ PCIe Workstation
Intel® Core™ i7 2700K @ 4.10GHz
16384MB DDR3 @1333MHz Dual Rank Interleave
nVidia® EVGA® GeForce® GTX 580 Classified 3072MB GDDR5
500GB 7200RPM SATA 6.0Gb/s 16MB Cache IntelliSeek™
Asus® P8P67 Motherboard
27" S27A350H ToC Samsung® SyncMaster™ Wide LED 2ms. 1920x1080
850W Corsair® TX Series Power Supply
Microsoft® Windows® 7 Professional Edition 64Bit SP1
Product Design Suite Premium 2012 SP1
17 sec. (Inventor 64-Bit 2012 SP1)
15 sec. (Inventor 64-Bit 2011 SP2)
Operating System: 64-bit Microsoft Windows 7 Ultimate (Build 7601) Service Pack 1
Processor: Intel(R) Core(TM) i7 CPU, 960 @ 3.20GHz (1 processor, 4 cores, Hyperthreading enabled)
System Memory: 12288MB RAM
Display: ATI Radeon HD 5800 Series,
DAC Type: Internal DAC(400MHz)
Graphics HW Memory: 2793 MB
Display Mode: Dual DVI, 1920 x 1080 (32 bit) (60Hz)
DirectX Version: 10.0
18sec. +/- .50sec.
Win 7 Pro. 64-bit SP1
Inventor 2012 Pro. SP1 64-bit
6GB RAM
Xeon 3.07GHz
NVIDIA Quadro 4000
If I add another 6GB of RAM, will that increase the performance?
17 sec.
@KF090 wrote:Now if I got into very large assemblies, that's where more RAM would help, correct?
Definitely, but as stevec781 suggested, check your process monitor (ctrl+shift+esc) to keep an eye on how much RAM Inventor uses, as you might be just fine with what you do now. I would normally recommend a minimum 8Gb for laptops, 12Gb for workstations, before even asking what it is that you do with Inventor.
Sorry to dig up old thread but just wanted to add results for new machine for those that might be considering a new build.
My old machine at 3.0GHZ - 24 sec, overclocked to 3.4GHZ - 19sec. Extra 0.4GHz gives 5 second improvement. (20%)
New machine- I7 2700k, 16Gb ram (2133Hz), SSD for data, GTX 560 (only because I had one), win7 64
3.6 Ghz - 16.5 sec
3.8Ghz - 15.5 sec
4.0 GHz - 14.3 sec
4.2 Ghz - 13.2 sec
0.4GHz gives 2.2 sec improvement (13%)
16Gb ram bought because they didnt have a 8Gb kit at 2133. Most of it sits unused.
15.1 seconds with Inventor 2012 SP1.
HP Pavilion h9-1150t
Windows 7 Enterprise x64 SP1
Intel® Core™ i7-3820 CPU @3.60Ghz, HT disabled
16 GB RAM
160 GB Intel 320 SSD, 1TB HD
nVidia GTX 480 driver 296.10
Dual monitors at 1680*1050
Space Navigator driver 6.15.3
