Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Re-lettering View Identifiers
5 REPLIES 5
DRoam
2695 Views, 5 Replies
HI,
I'm making a drawing in Inventor and I have several views and details and sections. Throughout making the drawing, I've created and deleted views. Whenever I do this, say the first view I placed was 'L', and then I delete view 'L', and make a new view. Inventor automatically labels this view 'M' instead of 'L', even though I don't have an 'L' view. This has caused me to have big gaps in the lettering of my views. Is there a way to "reset" the lettering so Inventor goes back through and re-letters everything starting from 'A'?
Thanks for your help.
5 REPLIES 5
Cadmanto
in reply to: DRoam
Welcome to the forum.
See if this thread helps you.
http://forums.autodesk.com/t5/Autodesk-Inventor/How-do-I-reset-the-view-identifier-number-in-the-idw...
Best Regards,
Scott McFadden
(Colossians 3:23-25)
karthur1
in reply to: DRoam
Thats an age-old problem that has been logged, but sadly never addressed.
Here is a link to a post about this issue from 2006.  It was logged as ID 865597.  Maybe someoone can look this up and give us a status Smiley Happy
DRoam
in reply to: DRoam
Unfortunate there's not a way to do that šŸ˜• thanks all for the help.
dennishoegh
in reply to: karthur1
This is still a returning issue for several reasons.
Do you have a status on this 8 year old issue? (Logged as ID 865597, see above)
Tags (1)
monica.thommen
r-click on the arrow, select 'edit first text' or 'edit second text' depending on which arrow you want to update. Then you can use the 'add parameter' button to drop the view identifier into the text field.
