Inventor General
Message 1 of 2 (58 Views)
Re: Text in Iassemblies
58 Views, 1 Replies
07-06-2012 05:56 AM
Hello All,
I am generating files through the Iassembly and I realize that I have a slight problem. I want to be able to put text on each of my generated assembly files, but I cant figure out how to reflect it in my Table Author. As it is now, If I place text on my model through the machining environment in Edit Factory Scope, it is going to be the same text for all models. I could create individual text through the Edit Member Scope, but then I start creating numerous columns in my table author all for some text. I'm trying to keep the number of columns in my table author to a minimum.
I could place the text on the individual components in a location where all of the text will appear on each model, but then they are instances where some components could be shared across multiple models. All in all I wish I could create the extrusion in the edit factory scope, and use some sort of dialog box or something to indivdually type the text in for each model. Any help on this issue would be appreciated
Product Support
innovatenate
Message 2 of 2 (34 Views)
07-19-2012 06:18 PM in reply to: dcmorgan
Do you have an example file that you could attach?
Nathan Chandler
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
