Inventor General
Active Member
Message 1 of 2 (128 Views)
Re-Sizable Panel
128 Views, 1 Replies
11-12-2012 07:33 AM
I was hoping someone could help me with the following issue.
I would like to make a aluminum framed panel template that I can enter in the height and width dimensions and then save the panel assembly into it's own unique part#. Right now, when I design enclosure, I will have multiple sizes of framed panel and I typically have to manually change the length and width dimensions for the individual extrusion members, then change the panel size manually. I re-name the new extrusions and panels to avoid file name conflicts. Is there a way to simplify the process?
Like I said before, I will have multiple "section"(SEC) assemblies in each main assembly file.
I attached a zip file with my aluminum framed panel assembly.
*Expert Elite*
PaulMunford
Message 2 of 2 (111 Views)
Re: Re-Sizable Panel
11-12-2012 01:37 PM in reply to: jbauer
Look into skeletal modelling:
http://cadsetterout.com/inventor-tutorials/assembly-techniques-for-woodworkers-the-skeletal-modellin...
or iCopy:
http://cadsetterout.com/inventor-tutorials/autodesk-inventor-icopy-tutorial/
Copying an Inventor assembly has it's wn challenges. There's some good advice here:
http://cadsetterout.com/inventor-tutorials/the-secrets-of-copying-assembly-files/
Let us know how you get on!
Paul
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
