Inventor Forum
Radius cut on Hex Nut
2 REPLIES 2
959 Views, 2 Replies
Hi ,
Does anyone know how to do a rwdius on a hex nut as shows in attached JPEG image. I am attaching my ipt file as well without radius.
Thanks.
2 REPLIES 2
brendan.henderson
Exaggerated radius but see attached.
Please include in your post which INV version you are running so people with older INV versions don't waste time downloading the INV file if they have an older version.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
JDMather
I didn't make any attempt to optimize this (I noticed your first sketch wasn't constrained and appeared to be an AutoCAD import), but here is another technique using Extrude - Intersect rather than Revolve - Cut.
