Inventor General
Valued Contributor
Message 1 of 27 (250 Views)
Accepted Solution
Radii in 3D sketches...
250 Views, 26 Replies
04-27-2012 02:52 AM
Anyone out there had problems trying to put a fillet on a 3D sketch?
I have a corner interface that is made up of an arc to a straight line...and can I heck as like put a fillet on that corner.
Is it possible or just a facility that doesn't work on arc/line interfaces?
regards
Gary
*Expert Elite*
Message 2 of 27 (238 Views)
Re: Radii in 3D sketches...
04-27-2012 04:45 AM in reply to: knowga
Works fine here.
Attach the file that exhibits this behavior.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Valued Contributor
Message 3 of 27 (229 Views)
04-27-2012 07:16 AM in reply to: knowga
Have a play with this...
there is only one radius to complete...
if you're able to radius it, we must be missing an update somewhere down the line...
regards
Gary
*Expert Elite*
Message 4 of 27 (220 Views)
04-27-2012 08:05 AM in reply to: knowga
See attached.
You will have to reproduce since this was done in edu version.
Oops, what version did you say you are using?
The trick is to use 3 point arcs rather than those Include Geometry arcs.
Valued Contributor
Message 5 of 27 (210 Views)
04-27-2012 09:26 AM in reply to: knowga
The version Im using is IV2011.
Hopefully I'll make it work on Monday (at home now)
thanks for your help...if it works, Ill report this as solution accepted.
regards
Gary
Valued Contributor
Message 6 of 27 (188 Views)
04-30-2012 12:36 AM in reply to: knowga
I couldnt load it...you're using IV2012...Im on 2011...
but I tried the 3 point arc...and that wouldn't work for me...
I snapped to one line, snapped to the other...the centre can be anywhere...
but when I tried to apply a tangential constraint for the arc to the snapped lines, it wouldn't do it?
take me from here...
regards
Gary
trumpy81
Message 7 of 27 (183 Views)
04-30-2012 02:28 AM in reply to: knowga
In 3D Sketch9 the first half of the geometry is drawn, but the second half is projected (from what I don't know), so if you are trying to fillet the projected part of the path it won't work. You would need to go back to wherever that geometry was projected from and alter it there.
HTH
Regards
Andy M
Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
Valued Contributor
Message 8 of 27 (173 Views)
04-30-2012 06:27 AM in reply to: trumpy81
The projected line is an arc...the line it connects to is at an angle of 25 degrees from the plane of the projected line.
This creates a compound angle i need to put a radius on.
Going back to the projected line wouldn't help.
I'm finding i can't radius 2 arcs in a 3D sketch...and I can't make an constrain an arc tangential to a line in 3D sketch either.
regards
Gary
*Expert Elite*
Message 9 of 27 (168 Views)
04-30-2012 06:44 AM in reply to: knowga
What problem are you having creating the 3-point arcs in the 3D sketch as instructed earlier in Post #4?
*Expert Elite*
Message 10 of 27 (168 Views)
04-30-2012 06:46 AM in reply to: JDMather
Did 2011 have this tool?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
