MY INITIAL SKETCH ON THE XY PLANE WAS REVOLVED
300 DEGREES. I HAVE FINISHED THE COMPLICATED PART,
AND NOW AM READY TO CREATE THD IDW.
I WOULD LIKE TO HAVE THE SIDE VIEW (EITHER)SPLIT
DOWN THE CENTER OF THE ROTATION (150 DEGREES), BUT
THE VIEW IS GENERATED AT 0/180 DEGREES.
I REALIZE NOW THAT I SHOULD HAVE CREATED MY INITIAL
SKETCH ON A ROTATED PLANE (30 DEGREES), BUT THERE
HAS TO BE AN EASY WAY TO ROTATE THE PART/WORK PLANE
ONCE THE PART HAS BEEN GENERATED.
I HAVE USED THE "CURRENT" VIEW IN THE IDW, BUT WHEN
I NEED TO USE THE LEFT AND RIGHT, I GET A VIEW OF
THE PART THAT IS 30 DEGREES OFF FROM WHAT I WANT.
THANKS IN ADVANCE,
