Inventor Forum
RMB Menus
43 REPLIES 43
Message 1 of 44
1014 Views, 43 Replies
RMB Menus
Can I add commands (Rotate View) to a RMB menu?
43 REPLIES 43
Message 2 of 44
I wish!
I want all the view commands added to the RMB instead of just ISO view and Previous view. Not sure I understand Autodesk's thought process behind this.
Ok, they can leave out pan and zoom since that's mouse enabled. I would like them to add "zoom extents" via double-clicking middle mouse button as in Autocad.
MechMan
Message 3 of 44
FYI...the F4 key initiates the rotate command.
There was a thread in the old NG about using MS Intellipoint mouse drivers with a 4 button mouse that would allow you to use the 4th button to initiate the rotate command.
MechMan
Message 4 of 44
I have a mouse with a thumb button but can not get
the dang F4 to work.....I am sick and tired of going up to menu bar every 10
seconds.....Any suggestions???
I
wish!
Autocad.
MechMan
Message 5 of 44
Are you using the MS drivers? Even if it's not a MS mouse. This was discussed in the old NG but I haven't tried it with my Logitech 4 button mouse.
MechMan
Message 6 of 44
You can map the thumb button to F4 directly with
Intellipoint 3.2, but in 4.x you will need to set it up using
keystroke.
~Larry
Message 7 of 44
Most of the power users here swear by the addition of a Spaceball for viewing and initiating additional commands. They say you can get one fairly cheap on eBay. I don't have one. B-(
MechMan
Message 8 of 44
Ya....I was part of those
discussions.....unfortunatly it did not work for me :(...
FYI...the
the rotate command.
MechMan
Message 9 of 44
mechman, get one! you'll love it. it's that nice edition of leather in your car (hi sean) . -Joe
Message 10 of 44
I am using "Cordless MousemMAN Optical" M/N
M-RM63  PN 851173-0000 and can not get the "F4 Keystoke to
work"
Message 11 of 44
Two questions come to mind: Did it successfully
map to F4 and not just 4 and does the F4 key on the keyboard work?
~Larry
Message 12 of 44
It's on my list to purchase for my next large IV contract job (which hasn't come yet). B-(
MechMan
Message 13 of 44
"F4" Works on the keyboard......and in mouse
properties I enable both thumb buttons and using the KEYSTROKE I hit "F4"
Key.....Still nothing.....I tested in Excel (F4 in office will do the last
command) and that did not work either.
Message 14 of 44
Did you enable the Program specific buttons and
pick Inventor?
~Larry
Message 15 of 44
I think your on to something......I have browsed to
the invetor directory but what do I select?  I am getting
excited.....
Message 16 of 44
You do it in the Mouse dialog. There's a tick box
to enable program specific buttons at the bottom of the dialog and then a
Settings button over to the right. You pick Inventor in the settings
dialog.
~Larry
Message 17 of 44
Just tried it and even rebooted (also added excel)
and both still do not work....I hate roller coaster rides....Do you have the
same mouse?
Message 18 of 44
I have Explorer 3.0 Optical but no reason it
shouldn't work with the cordless. The only difference is the way it's connected;
it gets the same information flow wire or no wire. I'll put a cap in CF to see
if we're talking the same settings.
~Larry
Message 19 of 44
I am sorry, how do I get to the CF....to see the
capture
(full quote back of all messages snipped off - moderator)
Message 20 of 44
I have an Explorer 3.0 optical, but a wire or no
wire shouldn't make any difference; same info/different medium. I put a cap in
CF to see if we're on the same page. If not, as I said, it's much less
involved with the Intellipoint 3.2 drivers because it will map F4 directly
from the dropdown for the thumb button. The difference being the thumb button in
3.2 is a global setting.
~Larry
