Inventor General
Member
plentung
Message 1 of 2 (194 Views)
RESET STYLE EDITOR IN INVNETOR 2012
194 Views, 1 Replies
11-02-2011 08:42 PM
Hi... all
I'm a newbie and still learning autodesk inventor, I have problem about tolerance. My tolerance more big than my primary dimension. How to edit this text..? or how to reset style editor for factory setting..?
Employee
AlisonDavis
Message 2 of 2 (169 Views)
Re: RESET STYLE EDITOR IN INVNETOR 2012
11-03-2011 04:53 PM in reply to: plentung
What version of Inventor?  What kind of dimensions (in part, sketch, drawing)?  I'm assuming you are creating dimensions in drawings using a relatively new version of Inventor.  You can modify Dimension Styles using the Styles editor (see this complete article describing Inventor styles:
http://mfgcommunity.autodesk.com/files/20301_20400/20363/file_20363.pdf) or edit the dimension itself by right clicking on the dimension text, selecting the menu item "Edit" and then entering tolerance data on the Precision and Tolerance tab.
Alison Davis
Autodesk Inc.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
