Inventor Forum
RESET STYLE EDITOR IN INVNETOR 2012
1 REPLY 1
362 Views, 1 Reply
Hi... all
I'm a newbie and still learning autodesk inventor, I have problem about tolerance. My tolerance more big than my primary dimension. How to edit this text..? or how to reset style editor for factory setting..?
1 REPLY 1
AlisonDavis
What version of Inventor?  What kind of dimensions (in part, sketch, drawing)?  I'm assuming you are creating dimensions in drawings using a relatively new version of Inventor.  You can modify Dimension Styles using the Styles editor (see this complete article describing Inventor styles:
http://mfgcommunity.autodesk.com/files/20301_20400/20363/file_20363.pdf) or edit the dimension itself by right clicking on the dimension text, selecting the menu item "Edit" and then entering tolerance data on the Precision and Tolerance tab.
Alison Davis
Autodesk Inc.
