Inventor General
*Jaquith, Walt
Message 1 of 5 (45 Views)
R6SP1 Scrambled Text: a new twist
45 Views, 4 Replies
11-18-2002 07:34 AM
It's my day to post screen caps, I guess.
In the center of pic there are two driven dimensions. One is 1.375", and
the other is .438". If you look close you can see that the left parenthesis
is a "2", or at least part of a two, and the right one is a "3". This is a
variation on the scrambled text problem that I've never seen. As with the
other scrambled text problems we've seen, restarting Inventor fixed the
problem.
I was really hoping that SP1 would put this one to bed :-2
WJ
*Howard, Jeff
Message 2 of 5 (45 Views)
Re: R6SP1 Scrambled Text: a new twist
11-18-2002 08:14 AM in reply to: *Jaquith, Walt
I had a garbled idw sketch text happen today (shut down / restart / A-OK).
Haven't seen the dim one in a while... guess it's just a matter of time. I
wonder what happens if you use a garbled dimension in an equation? Wow, it
could be a portal another dimension. 8~)
"Walt Jaquith" wrote in message
news:1C8C039437616873DB200F59739D2501@in.WebX.maYIadrTaRb...
problem.
WJ
*Caldwell, Larry
Message 3 of 5 (45 Views)
11-18-2002 09:00 AM in reply to: *Jaquith, Walt
I was seeing garbled text and decided it was a video driver issue but
certainly not the only one I've run into with R6. None of the drivers
normally recommended worked so I let Windows Update decide and so far ... so
good. Haven't seen any issues yet, but I just installed the new driver this
morning.
~Larry
parenthesis
a
> problem.
> WJ
*Crain, Ron
Message 4 of 5 (45 Views)
11-18-2002 11:27 AM in reply to: *Jaquith, Walt
I am also seeing garbled text in IDW's - printing is fine. Shut down
Inventor and restart clears it up mostly but it is a PAIN to do this
frequently.
parenthesis
a
> problem.
> WJ
*Rasmussen, Ed
Message 5 of 5 (45 Views)
Re:
11-18-2002 10:08 PM in reply to: *Jaquith, Walt
I have this problem at times as well. However, the garbled text (7 showing
like C) will preview and print garbled. With mine, exiting Inventor will
normally clear it up. Exiting the drawing only does not help.
Ed R
"Ron Crain" wrote in message
news:05DA7F5D59D2C38C31397EF8B1C39D63@in.WebX.maYIadrTaRb...
> frequently.
and
> parenthesis
is
> a
the
> > problem.
> > WJ
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
